Tour staring zoomed and without zoomabilty on ipad
robarama
by robarama » Sun Jan 12, 2014 7:47 pm
My tour loads zoomed out on my desktop but on my iPad it starts zoomed in without the ability to zoom further in our out. Does anyone know a fix for this?
http://www.robertgranoff.com/test/SE_8t ... ers_c.html
Thanks,
R
Re: Tour staring zoomed and without zoomabilty on ipad
by mediavets » Sun Jan 12, 2014 8:38 pm
robarama wrote:My tour loads zoomed out on my desktop but on my iPad it starts zoomed in without the ability to zoom further in our out. Does anyone know a fix for this?
Thanks,
R
Are you using PTP RC1?
robarama
by robarama » Sun Jan 12, 2014 9:26 pm
I'm not sure. I've had this thing so long, I thought it was from the first round of iPads. I'm updated the os not to 7.0.4. Maybe that will make a difference. One last question if I may:
Regarding Tiles, when is it recommend to use
"multi resolution," "Incremental build," or "Rebuild all tiles" ?
I've been trying different combinations and I don't really see any difference in the tours.
Thanks again you've been supremely helpful today!
R
by mediavets » Sun Jan 12, 2014 9:31 pm
robarama wrote:I'm not sure. I've had this thing so long, I thought it was from the first round of iPads. I'm updated the os not to 7.0.4. Maybe that will make a difference. One last question if I may:
R
If you created the tour in RC1 then use incremental build.
You will/should see a difference if you don't select multi-resolution unless your input images are themselves very low res.
robarama
by robarama » Sun Jan 12, 2014 9:34 pm
So I should go with the default, which is multires and incremental and forget about rebuild unless I'm working with older version creations?
by mediavets » Sun Jan 12, 2014 11:11 pm
robarama wrote:So I should go with the default, which is multires and incremental and forget about rebuild unless I'm working with older version creations?
I would.
robarama
by robarama » Sun Jan 12, 2014 11:43 pm
Ok many thanks for all of your help. It literally changed my entire day.
