How to... Question
tamiro
Likes: 12 posts
How to... Question
by tamiro » Sun Jan 12, 2014 11:46 am
hi all
i have a few question about video in PTP 2.0
1. i wish to add video that will display inside the tour as a video spot
BUT i want it to have a way to control it
i want it to start after the first click and after the second clik to jump out (like a regular spot)
can i do it some how?
2. how to make a video spot that will stop and close itself after i'm opning new command such as another video or a gallery?
tanx
Tamir
Re: How to... Question
by mediavets » Sun Jan 12, 2014 1:48 pm
tamiro wrote:hi all
2. how to make a video spot that will stop and close itself after i'm opening new command such as another video or a gallery?
tanx
Tamir
You may be able to do something like this if you display your video using a Video box viewer plugin, or a Web site box plugin?
tamiro
Likes: 12 posts
by tamiro » Sun Jan 12, 2014 7:44 pm
nop
it's not working that way....
any one??
by mediavets » Sun Jan 12, 2014 8:34 pm
tamiro wrote:hi all
tanx
Tamir
I'm not saying this is exactly what you wnat but is this not somewhat similar to what you seek?:
tamiro
Likes: 12 posts
by tamiro » Sun Jan 12, 2014 8:44 pm
it could be good but it's not work so good with my first issue
when i'm using video spot i can't use video box at the same hospot
because both are palying together at the same time
my thought was to add a video spot that will work at the first click
and the video will pop up at the second click like the video box do
by mediavets » Sun Jan 12, 2014 8:52 pm
tamiro wrote:mediavets
because both are playing together at the same time
I did understand that...but AFAIK it can't be done via the PTP GUI.
I was suggesting that instead of (rather than as well as) a video spot you display the video using a Web video box which obviously offers much greater control options for the video.
