Export cube faces problem
Bogdan
by Bogdan » Thu Jan 09, 2014 3:19 pm
Anyone knows why?
Liked in: 227 posts
Re: Export cube faces problem
by Destiny » Thu Jan 09, 2014 9:27 pm
Best you can hope for is TIFs but only if you use the krpano droplet.....
Besides, the PTP V2 Cube export feature is bugged... Depending on the size of your pano, it might effect the import back resulting in a 2:1 ratio issue..
by mediavets » Thu Jan 09, 2014 9:38 pm
Bogdan wrote:I can't export cube faces in .PSD format. It only exports in .jpg
Anyone knows why?
If you have a licensed version of PTP you can export your licenses and use them with krpanotools droplets which I believe can do support the format you seek:
http://krpano.com/tools/droplets/#convertspheretocube
Liked in: 227 posts
by Destiny » Thu Jan 09, 2014 11:40 pm
I tried that a long time ago Andrew.... As far as I know, you can only change the path, not the file extension.. I do not know where the reference to that is.. Best to send a message to Klaus krpano..
I am sure that PTP V2 will have this feature soon. I requested other export options, I have just added the PSD to this.. ;) viewtopic.php?f=92&t=20893&p=134459#p134459
by mediavets » Fri Jan 10, 2014 12:41 am
Destiny wrote:I tried that a long time ago Andrew.... As far as I know, you can only change the path, not the file extension.. ..
But presumably you can get out what you put in...so if you want PSD out put PSD in?
If you want format conversion then:
http://www.xnview.com/en/
Liked in: 227 posts
by Destiny » Fri Jan 10, 2014 1:12 am
No, sorry to say.. Input PSD output TIF...
by mediavets » Fri Jan 10, 2014 1:15 am
Destiny wrote:No, sorry to say.. Input PSD output TIF...
With what ? krpano tools?
