Custom menu
angelo2005
Custom menu
by angelo2005 » Tue Jan 07, 2014 4:46 pm
Hi
How I can create a menu like the one shown above right? (social media popup)
http://www.xavierspertini.com/360/haute-maurienne/
AlanS
Re: Custom menu
by AlanS » Tue Jan 07, 2014 5:29 pm
1) Create (or purchase) your sample graphic. That particular one has transparency so save as a PNG file with alpha.
2) In PTP, apply the Social Share plugin under the 'Viewers' option in the 'Style' plugin library
3) Then create a 'Simple Button' in Style tab -> Plugins Library -> Controls
4) In the button options that appear, under 'Display', choose your image file as the source and define the tooltip. Then a little further down under 'Actions triggered on click', choose 'Share Tour' under 'Interface Control' twirly.
5) That should do it.
angelo2005 wrote:Hi
Re: Custom menu
by Destiny » Tue Jan 07, 2014 7:32 pm
I made a quick button for you...Just drag it off from here.. Resize accordingly but make sure you save as a 24bit png.....
George Randy Bass
Re: Custom menu
by George Randy Bass » Tue Jan 07, 2014 11:10 pm
Thanks for the tip Destiny!
