Audio makes loading time looooong
Fabio Musio
by Fabio Musio » Thu Jan 02, 2014 6:39 pm
I have a 360 with an audio file of 2MB.
It looks like the audio is the first think to be downloaded, resulting in a black screen for 10 seconds.
Then the images start to appear. Any way to fix or improve this behavior?
Re: Audio makes loading time looooong
by mediavets » Thu Jan 02, 2014 6:51 pm
Fabio Musio wrote:I have a 360 with an audio file of 2MB.
Reduce the size of the audio file; you might try reducing the bit-rate for example.
AlanS
by AlanS » Thu Jan 02, 2014 6:56 pm
This has been my experience as well. A possible solution (if you're comfortable editing XML) is found here...
http://www.kolor.com/forum/viewtopic.php?f=91&t=20565&hilit=preload
As a future feature request, I would like a checkbox in the 'advanced' section of the GUI to optionally enable/disable audio file preload, OR an option to post-load audio files (if that's even possible).
EDIT: That said, 2mb is a pretty small file, this shouldn't adversely affect the entire load time... I wonder if there are other processes going on that interfere when preloading? Server-side confirmation of preloads or something?
Alan
Fabio Musio
by Fabio Musio » Thu Jan 02, 2014 11:17 pm
I'm trying to figure it out.
Thanks!
