Changing the transparency of the control bar ...
pollarda
by pollarda » Thu Dec 26, 2013 1:37 am
Is there a way to change the transparency of the classic control bar? Of all the bars, the classic is the one that I feel fits my needs the best. However, with the semi-transparency, it tends to get lost visually. I would like to be able to change the transparency and even make the control bar totally solid if I choose.
Is there a setting somewhere to do this? It makes sense to be able to control this somehow as some panoramas may need solid control bars and others semi-transparent given the specific colors used in the panorama.
Thanks,
-Art
Re: Changing the transparency of the control bar ...
by mediavets » Thu Dec 26, 2013 11:36 am
pollarda wrote:Is there a way to change the transparency of the classic control bar? Of all the bars, the classic is the one that I feel fits my needs the best. However, with the semi-transparency, it tends to get lost visually. I would like to be able to change the transparency and even make the control bar totally solid if I choose.
Thanks,
-Art
It appears that a degree of transparency is always applied to the background even if you specify that it should be completely opaque.
Is this a bug?
by Destiny » Thu Dec 26, 2013 11:45 am
Its being fixed.... Kolor are aware of it..
jschrader
Liked in: 3 posts
by jschrader » Thu Dec 26, 2013 5:59 pm
Since many months already :-)
by benji33 » Tue Dec 31, 2013 9:48 am
Yes ;) Will be done quickly.
by Destiny » Tue Dec 31, 2013 9:53 am
That's Kolor talk for "Next Year" :lol: :lol:
Destiny....
by mediavets » Tue Dec 31, 2013 10:14 am
Destiny wrote:That's Kolor talk for "Next Year" :lol: :lol:
Destiny....
Not today then? :p
Users browsing this forum: No registered users and 12 guests
