Display an image on polygon hotspots
kahlilcalavas
by kahlilcalavas » Tue Dec 03, 2013 9:54 pm
All of my old 1.8 projects have polygon hotspots that display an images of a nice png arrow I made for moving around the rooms. It seems now in 2.0 we are no longer able to display an image inside of the polygon hotspots. Am I missing something. I need to display an image inside of my polygon hotspots. I know there is a image spot but this has crashed when I try to link a panorama to it.
Re: Display an image on polygon hotspots
by mediavets » Tue Dec 03, 2013 11:41 pm
kahlilcalavas wrote:All of my old 1.8 projects have polygon hotspots that display an images of a nice png arrow I made for moving around the rooms. It seems now in 2.0 we are no longer able to display an image inside of the polygon hotspots. Am I missing something. I need to display an image inside of my polygon hotspots. I know there is a image spot but this has crashed when I try to link a panorama to it.
PTP 1.8 didn't/doesn't allow a Polygon hotspot to have an object (image) fill.
But the Rectangular hotspot did.
I think the Picture hotspot in PTP 2.x is roughly equivalent to the Rectangular hotspot in PTP1.8.
kahlilcalavas
by kahlilcalavas » Wed Dec 04, 2013 12:52 am
Ok I guess i was using the rectangle then in 1.8. I used the picture hotspot but it crashes when I drag to link hotspot to a panorama. I guess I'll use the drop downs to connect panos. Thank you
by benji33 » Wed Dec 04, 2013 10:13 am
Yes reproduced it's a bug. i add the report. thanks.
Solution : Change the style of the hotspot with a goto action
then select this for the hotspot
then use the properties panel on the right to select a target panorama for your picture hotspot. thanks.
