Cannot add project description on tour and location on maps
razvan_xr
by razvan_xr » Sat Nov 30, 2013 9:33 pm
Hi!
I'm using Panotour pro 2.0 plus Livepano and I'm having a hard time putting a text description to a tour. I've dragged the Description from the right side of Styles, made all the settings, and there is no effect when I press the i button on tour.
Also, I've inserted the geo coordinates on panorama, and no maps are displayed.
Please help! Thanks
Re: Cannot and project description on tour and location on m
by mediavets » Sat Nov 30, 2013 9:51 pm
razvan_xr wrote:Hi!
Can oiu show us a screenshot of your decsription plugin settings?
Have you created Descriptions for Panoramas and or Groups and or Project in the relevant Properties panels in the Tour section.
Please help! Thanks
But have you added a Map plugin to your Workspace in the Style section and configured it appropriately?
Finally are you viewing the tour online or offline.
If offline the you need to use the View last built tour... button in PTP 2.0 to ensure all features work correctly.
razvan_xr
by razvan_xr » Sun Dec 01, 2013 3:03 pm
Here is the screen capture, for both maps and description
Also, I wrote the project description, and added geo coordinates to the project
I'm viewing the tour offline for now, and I am refreshing manually my window, I'm aware of the problem with the view my last tour button
Thanks for your reply!
by mediavets » Sun Dec 01, 2013 5:36 pm
razvan_xr wrote:Here is the screen capture, for both maps and description
You need to enter a map key for the Map to work; cannot remember whether the Google maps work offline, Bing Maps do for me using Firefox 25 on Windows 8.1.
I cannot see from the screenshot why the description would not work if you use the View last built tour... button to view the tour offline.
Can we see a Tour section screenshot that displays the Project properties with the project Description ?
razvan_xr
by razvan_xr » Sun Dec 01, 2013 6:05 pm
The project has a title and a description
I've inserted the title from the style screen and it's working
Just under the project title there is the description as you can see
by mediavets » Sun Dec 01, 2013 6:12 pm
razvan_xr wrote:Thanks for your reply!
Yes; then I don't understand why the project description is not being displayed, assuming that you are viewing using the View last built tour... button. If you don't it won't display.
You could try Building the tour to a new folder using a different filename.
razvan_xr
by razvan_xr » Sun Dec 01, 2013 6:25 pm
This is not important for now. Can you give me some advices for making smaller mb tours or do I have to pen a new topic?
by mediavets » Sun Dec 01, 2013 10:07 pm
razvan_xr wrote:This is not important for now. Can you give me some advices for making smaller mb tours or do I have to pen a new topic?
Best to start a new topic.
