Didi wrote:http://www.edouarddeblay.com/360/iglulikcity/
if i want to use the arrows, the map turns ,not the 360.Is it possible to get only the 360 turning?
Didi wrote:exactly, the keyboard . You can try with the link above
mediavets wrote:
It just depends on which has focus.
Not here. Only the map is moving.
HA
