Multiple MP3 in a pano solved?
MackyLuke
by MackyLuke » Thu Nov 28, 2013 6:29 pm
I rad on this forum that multiple sound in ONE pano was a forgotten feature in PTP2.
Is this problem solved?
Is there a work around like use a different JS to start each MP3?
Luc
Re: Multiple MP3 in a pano solved?
by mediavets » Thu Nov 28, 2013 6:32 pm
MackyLuke wrote:I rad on this forum that multiple sound in ONE pano was a forgotten feature in PTP2.
Luc
The ability to play a sound from a hotspot is said to be back in beta 5 - now available for downlaod.
MackyLuke
by MackyLuke » Thu Nov 28, 2013 7:00 pm
Good… It's now working. Now on Beta 6, we need an option so if, during a sound is running the user click on another button, the first one should stop before the 2nd one starts. Otherwise, I can run 6 different voices which becomes useless information.
by mediavets » Thu Nov 28, 2013 7:12 pm
MackyLuke wrote:Good… It's now working. Now on Beta 6, we need an option so if, during a sound is running the user click on another button, the first one should stop before the 2nd one starts. Otherwise, I can run 6 different voices which becomes useless information.
What would you (want to) do about background sound or directional sound(s)?
MackyLuke
by MackyLuke » Thu Nov 28, 2013 7:15 pm
No, I do not want to affect other sounds. Just the one activated by a button. But it could also be a nice feature to be able to manage a background sound as well.
by mediavets » Thu Nov 28, 2013 7:28 pm
MackyLuke wrote:No, I do not want to affect other sounds. Just the one activated by a button. But it could also be a nice feature to be able to manage a background sound as well.
And if you also had an embedded video loop with audio?
Likes: 60 posts
Liked in: 169 posts
by benji33 » Mon Dec 02, 2013 11:41 am
Yes a bug exists with play sound action which can't be stopped. It's a known bug in our todo list.
Users browsing this forum: No registered users and 8 guests
