Embedding
Peter Stephens
Embedding
by Peter Stephens » Sun Nov 24, 2013 4:49 pm
Trying to embed a panotour v2 tour into a website, and failing...... just ain't working. What code should I be using?
Peter
Likes: 82 posts
Liked in: 183 posts
Re: Embedding
by benji33 » Mon Nov 25, 2013 9:28 am
Generated html file contains the code to use. Need a div to contain the tour and a javacript to embed code. If you are using javascript/HTML5 plugins, some other libraries need to be loaded. Look after your html template content.
Peter Stephens
Re: Embedding
by Peter Stephens » Thu Nov 28, 2013 12:20 am
Thank you for your reply. Have been playing around with this again this evening, but still having no luck. Here's a link to the page I'm working on -
http://www.peterstephens.co.uk/virtual_ ... v-2013.php
I would like it to embed on a page like this http://www.peterstephens.co.uk/property ... l-tour.php
Expect it's something simple, I'm not great with code.
Pete
Re: Embedding
by mediavets » Thu Nov 28, 2013 10:41 am
Peter Stephens wrote:Thank you for your reply. Have been playing around with this again this evening, but still having no luck. Here's a link to the page I'm working on -
Pete
So who is creating these PHP pages for you? Or are you using some sort of templated web site builder?
Not certain but i think iframes may be what you need:
http://www.w3schools.com/tags/tag_iframe.asp
Likes: 82 posts
Liked in: 183 posts
Re: Embedding
by benji33 » Thu Nov 28, 2013 11:31 am
It works now.
Peter Stephens
Re: Embedding
by Peter Stephens » Thu Nov 28, 2013 2:08 pm
mediavets - I'm creating the php, only for the header and footer. If I use an iframe wouldn't that effect the full screen option for html5? I wouldn't use iframe for this reason.
benji33 - The 360vr image works yes, but it's not embedded on my webpage as with the other example.
Pete
Likes: 82 posts
Liked in: 183 posts
Re: Embedding
by benji33 » Thu Nov 28, 2013 2:30 pm
The first screenshot is your PTP 1.8 inclusion.
Simply replace the content of the <td> (script + div container) by the screenshot 2 <div id="container"> and all it's content.
Then add the scripts of the screenshot 3 to the <head> tag (the highlight script can be removed).
This should work. Some css adjustement will be perhaps necessary into the added <style type="text/css"> tag which can overide some of yours.
Also, for iframe, it works great but you must add the allowfullscreen attribute into the iframe tag.
Peter Stephens
Re: Embedding
by Peter Stephens » Thu Nov 28, 2013 2:37 pm
Thank you, will give it a go now. I didn't know about the allowfullscreen attribute for iframes, that's good to know.
Pete
Peter Stephens
Re: Embedding
by Peter Stephens » Thu Nov 28, 2013 3:47 pm
Ok getting there
http://www.peterstephens.co.uk/virtual_ ... 3-test.php
Though page isn't centred and the the tour is the wrong size. I got this far a couple days ago and tried to change the dimensions from 100% to set pixel dimensions, couldn't get that to work. Will give it another go.
Peter Stephens
Re: Embedding
by Peter Stephens » Thu Nov 28, 2013 3:54 pm
Sorted the tour window size out now, seems like it doesn't like being given pixel dimensions and would rather be kept at 100%, now just need to correct the rest of the page layout. Wish I understood code better, is really frustrating when it doesn't work. Thank you for your help :-)
Pete
Peter Stephens
Re: Embedding
by Peter Stephens » Thu Nov 28, 2013 4:04 pm
Just need to centralise the page and get the scroll bar back, any ideas?
Pete
Likes: 82 posts
Liked in: 183 posts
Re: Embedding
by benji33 » Thu Nov 28, 2013 5:05 pm
Add a <div> container into <body> which will be centered to center all the code/all div into.
For scrollbar remove the highlight zones into this screenshot
For container size add a style to the <td> to define the container size, so the player will be 100% by 100% and compatible for fullscreen (see screenshot)
Peter Stephens
Re: Embedding
by Peter Stephens » Thu Nov 28, 2013 5:18 pm
Cool !! All working now :-) Thank you again.
Pete
edgar_ali
Liked in: 3 posts
Re: Embedding
by edgar_ali » Fri Feb 21, 2014 1:11 am
I am currently using Panotour Pro 2.0 . I have created a tour and uploaded in:
http://flash.imaginephotographs.com.au/?page_id=10
As you can see in that page, the tour is display as a little square. I have change the width and height properties in the panopress link and settings (as you can see in the following links: http://www.screencast.com/t/uM5pjOQd ; http://www.screencast.com/t/9qj1b4rtQTsP ; http://www.screencast.com/t/Ic9fTK5i )
As you can see in: http://flash.imaginephotographs.com.au/?page_id=10 the panorama is display as a rectangle, eventhough I have established in the settings a width and a height of 700px (http://www.screencast.com/t/9qj1b4rtQTsP)
Why is that?... how can I display my panorama as a square (700 x 700 px ) instead of a rectangle as it is now?
My second question is:
I have uploaded my panorama here: http://flash.imaginephotographs.com.au/?page_id=10
However I want to embed this panorama in: http://imaginephotographs.squarespace.c ... l-tours-1/
When I embed the panorama into this website, it display the whole website instead of the panorama.
The code that I’m using to embed this panorama into the website is:
<iframe src="http://flash.imaginephotographs.com.au/?page_id=10" width="800" height="600" allowFullScreen></iframe>
I would like my panorama to looks like this example:
http://imaginephotographs.squarespace.c ... ual-tours/ (be aware that I took this example from http://www.aircamera.fr (I will remove this tour after I understand what I need to do to show my tour as this)
If I launch the tour online using chrome, this is how it looks:
http://www.screencast.com/t/jxmMeTjQ6D
Please let me know if you need more info to help me
