What fullscreen options are available for smartphones?
andy4nothin
by andy4nothin » Sun Nov 24, 2013 2:03 pm
After using PTP2 to make my 360's smartphone savvy on my website, I was amazed to see not only the diminutive control bar button size, but the fullscreen button has disappeared. Why?
This, I was not expecting. If there's one button you do need in a smartphone its the fullscreen one! Is this a KRPano, smartphone or PTP2 issue?
Has anyone come up with a solution?
I'm thinking of detecting the browser to place a conditional fullscreen button that will launch my iframe page into its' own window, Perhaps with an additional script which detects if the window has a parent, and if not, a close button is included.
Does this sound feasable?
Re: What fullscreen options are available for smartphones?
by mediavets » Sun Nov 24, 2013 2:17 pm
andy4nothin wrote:After using PTP2 to make my 360's smartphone savvy on my website,
Which Smartphone are you using?
andy4nothin
by andy4nothin » Sun Nov 24, 2013 2:56 pm
Samsung Note 2
by mediavets » Sun Nov 24, 2013 3:24 pm
andy4nothin wrote:Samsung Note 2
And your preferred browser?
andy4nothin
by andy4nothin » Sun Nov 24, 2013 4:16 pm
I've been using Firefox.
Tried Chrome and I was surprised to see it ask for Flash!
by mediavets » Sun Nov 24, 2013 6:25 pm
andy4nothin wrote:I've been using Firefox.
Me too.
What version of Android do you have on your smartphone?
andy4nothin
by andy4nothin » Sun Nov 24, 2013 6:40 pm
4.1.2
by mediavets » Sun Nov 24, 2013 6:43 pm
andy4nothin wrote:4.1.2
I think 4.1.2 still supported Flash.
I think I read that they are rolling out 4.3 update globally for your Smartphone starting yesterday?
http://www.examiner.com/article/samsung ... ease-nears
andy4nothin
by andy4nothin » Sun Nov 24, 2013 6:58 pm
Adobe's Flash website says 'No!'. Unfortunately.
I read Steve Jobs thoughts yesterday, on why Apple moved away from Flash, and it would have largely made sense if there was a viable alternative.
HTML5 looks like it will be a nightmare on mobile handsets and tablets. No 2 devices appear to handle panos the same way.
by mediavets » Sun Nov 24, 2013 7:08 pm
[quote="andy4nothin"]Adobe's Flash website says 'No!'. Unfortunately.
HTML5 looks like it will be a nightmare on mobile handsets and tablets. No 2 devices appear to handle panos the same way.[/quote]
In the short(ish) term that's likley.
Older mobile handsets and tablets may never support HTML5 well partly for hardware reasons and partly also because many Android device makers don't seem to offer frequent Android upgrades although I believe Google is seeking to remedy that.
But since mobile handsets and tablets now seem to be considered 'consumables and obsolete within 2 years maybe that doesn't matter?
by benji33 » Mon Nov 25, 2013 9:36 am
The player use the devices="fullscreensupport" attribute. So if your device is detected with unsupported fullscreen feature, the fullscreen button will be ignored.
andy4nothin
by andy4nothin » Mon Nov 25, 2013 10:00 am
This is interesting, but when I load the Google+ photosphere player, that does play at fullscreen.
Is it possible to force the player to fullscreen?
by benji33 » Thu Nov 28, 2013 11:42 am
For xml modification to allow the button I've reported 2 posts here :
1. Create a plugin
To change on original code, create your own plugin.
Informations on this post : viewtopic.php?f=91&t=20018#p128856
Doc informations here : http://www.autopano.net/wiki-en/action/ ... our_plugin
Apply modifications into the plugin tmpl file.
2. Example with classic control bar plugin
Create a copy of theme2.tmpl file and change it's ID into tmpl file.
Into this copy of theme2.tmpl file remove the red lines below :
line 45
if (device.fullscreensupport,
set(layer[{{plugname}}btn_openfs ].{%ifequal p.position.orientationString "horizontal"%}x{%else%}y{%endifequal%}, get({{plugname}}button_pos));
set(layer[{{plugname}}btn_closefs].{%ifequal p.position.orientationString "horizontal"%}x{%else%}y{%endifequal%}, get({{plugname}}button_pos));
inc({{plugname}}button_pos, {{button_offset}});
line 585
<layer name="{{plugname}}btn_openfs"
url="%FIRSTXML%/{{pluginDirectory}}/btn_enter_fs.png"
onclick="{%include 'enterfullscreencall.tmpl'%}"
style="{{plugname}}_btn_style"
visible="false"
line 595
<layer name="{{plugname}}btn_closefs"
url="%FIRSTXML%/{{pluginDirectory}}/btn_close_fs.png"
onclick="{%include 'exitfullscreencall.tmpl'%}"
visible="false"
line 1233
<action name="{{plugname}}ShowFullscreenButtons">
if(tour_fullscreen,
set(layer[{{plugname}}btn_openfs].visible , false);
set(layer[{{plugname}}btn_closefs].visible, true);
set(layer[{{plugname}}btn_openfs].visible ,true);
set(layer[{{plugname}}btn_closefs].visible,false);
{{plugname}}HideFullscreenButtons();
</action>
Then into the generated XML code YOUR_TOUR_skin.xml
Remove devices="fullscreensupport" of actions : exitFullScreen, enterFullScreen, exitFullScreenChangeEvent, enterFullScreenChangeEvent
andy4nothin
by andy4nothin » Thu Nov 28, 2013 11:56 am
Thanks again Benjamin.
Looks interesting. I'll give it a go.
