Description Justification
Firefly360
by Firefly360 » Sun Nov 24, 2013 5:41 am
Dear Friends,
I recently make used of the Description module for PTP2.0. While there are the usual text formatting features, I don't find the sentence justification; like align center, left or right. How should I go about this?
Thanks!
Re: Description Justification
by mediavets » Sun Nov 24, 2013 9:10 am
Firefly360 wrote:Dear Friends,
Thanks!
If you want more control over the layout you might be better advised to use a Web site box instead.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Mon Nov 25, 2013 9:13 am
Yes, description editor is limited only for quick edition. It's not a full text editor.
Firefly360
by Firefly360 » Mon Nov 25, 2013 12:34 pm
Thanks for the replies guys...
Benji, can we possibly add sentence justification in the editor after Beta period? I just want the simple ability to center my text in the screen. Consider this 360VT of Typhoon Haiyan in the Philippines: http://www.360journals.com/360/Haiyan/t ... an360.html The overall text display would have been better if we have center justify :-)
Regards,
Likes: 84 posts
Liked in: 186 posts
by benji33 » Thu Nov 28, 2013 11:48 am
Into feature requests. Thanks
by mediavets » Thu Nov 28, 2013 11:53 am
benji33 wrote:Into feature requests. Thanks
I don't know why you don't just implement the description as HTML and provide a more competent embedded HTML editor for the Description?
Liked in: 227 posts
by Destiny » Thu Nov 28, 2013 12:08 pm
The Description plugin is a pain.. I realise it can be set to open on start Tour but thats about the only useful feature with this plugin.. You would be better off using a Website Box or an iFrame...
http://www.destinyvirtualtours.com/ifra ... tSpot.html
I am sure the auto open the Website Box on start Tour will be added at some stage.. That plugin is outstanding... Very useful....
