Timeout (while making map API call / very slow start tour
Sissi
by Sissi » Tue Nov 19, 2013 12:32 pm
I have conducted this virtual project of 15 panorama's:
www.schladming360.at/groebming
It takes mostly more than a minute to load this page. Sometimes it doesn't even start and it says:
"Connection timeout while making map API call. Try to reload the page."
Does anyone know what I should change to make the tour start faster?
Re: Timeout (while making map API call / very slow start tou
by mediavets » Tue Nov 19, 2013 1:24 pm
Sissi wrote:I have conducted this virtual project of 15 panorama's:
http://www.schladming360.at/groebming
I got the timeout message when accessing from the UK.
Perhaps you should try a different web host?
damarco123
by damarco123 » Tue Nov 19, 2013 1:37 pm
I Guess your load is to high.
http://tools.pingdom.com/fpt/#!/eewscn/ ... groebming/
try to reduce the Jpeg quality on the Build-Module in PT
by mediavets » Tue Nov 19, 2013 1:40 pm
damarco123 wrote:I Guess your load is to high.
Those MP3 files look like they may probably the problem?
I think they may get downloaded before the first scene gets displayed?
Likes: 60 posts
Liked in: 169 posts
by benji33 » Thu Nov 21, 2013 1:09 pm
Yes, the 17 mp3 loaded at start seems slow down the tour.
I've reported this problem.
Each sound is linked to a panorama ? to a spot ? as background sound ? Thanks
Likes: 60 posts
Liked in: 169 posts
by benji33 » Fri Nov 22, 2013 4:50 pm
In waiting you can try to remove the mp3 preload with XML editing of the index_skin.xml file. Add <!-- and --> to comment code and keep only the start mp3 into the preloadSounds action.
Example :
<action name="preloadSounds">
    preloadsound("every_step.mp3");
    preloadsound("crimson_fly.mp3");
    preloadsound("payday.mp3");
    preloadsound("whistling_down_the_road.mp3");
    preloadsound("denis mercier - oiseaux, insectes - rossignol.mp3");
    preloadsound("sound satttental.mp3");
    preloadsound("brontosaurus.mp3");
    preloadsound("mix_1m33s (audio-joiner.com).mp3");
    preloadsound("stalling.mp3");
    preloadsound("sound2.mp3");
    preloadsound("get_outside.mp3");
    preloadsound("getting_there.mp3");
    preloadsound("tracteur mixe.mp3");
    preloadsound("sound schwimmbad sankt martin.mp3");
    preloadsound("mix_24s (audio-joiner.com).mp3");
    preloadsound("sonclasic.mp3");
    preloadsound("grace_behind_the_curtain.mp3");
  </action>
Sissi
by Sissi » Sun Dec 22, 2013 9:42 am
Dear Benjamin!
Sorry for my late reply, I have been away, but now I am working on my 360-projects again.
Thank you so much for your very useful help! I removed the MP3 preload with XML by editing the index_skin.xml file (like you said) and now it's working fine :)
I also made these mp3 files much shorter (and just "loop" them).
Google Chrome and Explorer work really well. In Firefox it is a bit slower, but the good news is that it all works!
http://www.schladming360.at/groebming :cool:
Merci encore et très bonne journée!
Ellen
