INTEGRER UN PLAN   [SOLVED] - View the solution
Re: INTEGRER UN PLAN
by mediavets » Sun Nov 17, 2013 3:22 pm
No, like this:
nono44000
by nono44000 » Sun Nov 17, 2013 3:53 pm
nono44000
by nono44000 » Mon Nov 18, 2013 6:18 am
I try to change the direction of the view when the tour starts
I put a good position changing in Previews
but he does not keep in memory
how?
thank you
by mediavets » Mon Nov 18, 2013 9:02 am
nono44000 wrote:I try to change the direction of the view when the tour starts
how?
thank you
Use the Button or right-click (Windows) and choose the option to set the default view.
nono44000
by nono44000 » Mon Nov 18, 2013 11:39 am
my last question, and how to orient the radar in the same direction in terms
thank you again
by mediavets » Mon Nov 18, 2013 11:50 am
nono44000 wrote:my last question, and how to orient the radar in the same direction in terms
thank you again
The orientation of the radar depends on two factors:
1.The Compass direction set in the panorama 3D editor - screenshot 1.
2. The offset set for the floor plan in the Project or Group Floorplan settings - screenshot 2.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Tue Nov 19, 2013 10:54 am
Yes you can change the alpha to 0 for transparent background.
nono44000
by nono44000 » Thu Nov 21, 2013 2:27 pm
in hotspot editor
if I change the view
this is an effect
nono44000
by nono44000 » Thu Nov 21, 2013 2:29 pm
if I write a description
where can I find it in the visit
by mediavets » Thu Nov 21, 2013 3:11 pm
nono44000 wrote:if I write a description
You need to add a Text zone/description plugin (one or more) to your work space in the Style section.
You can then invoke the display of the description from a button on a Control bar, or via a hotspot, or a Simple button, or a Toggle button.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Fri Nov 22, 2013 1:31 pm
nono44000 wrote:if I change the view
this is an effect
what ?
nono44000
by nono44000 » Fri Nov 22, 2013 2:10 pm
est il possible d'avoir un reglage automatique du plan suivant grandeur ecran de reception
voir exemple de la vv du haut
http://votrevitrine.fr/
j'ai pu voir que l'aide fonctionne tres bien !
merci
nono44000
benji c'est ok pour moi
merci sur ta demande ou du - ma demande
nono44000
by nono44000 » Sat Nov 23, 2013 3:03 pm
is it possible to have an automatic adjustment of screen size following plan reception
see example of vv top
I could see that aid works very well!
thank you
nono44000
by nono44000 » Sun Nov 24, 2013 4:09 pm
in the last example of kolor
[Panotour Pro 2.0] Case study #5: University Campus | Fabio Musio photographer
http://www.100digitalcreativity.com/clients/OU/
we can see that the plan follows exactly the size of the screen
What should I do to it?
thank you
by mediavets » Sun Nov 24, 2013 6:32 pm
nono44000 wrote:in the last example of kolor
thank you
You need to check the parameter I've marked in the screenhot below:
nono44000
by nono44000 » Sun Nov 24, 2013 7:55 pm
thank
nono44000
by nono44000 » Fri Nov 29, 2013 3:22 pm
hello
I have a valid auto turn all 14s
http://votrevitrine.fr/reference/essai.html
but it does not work?
nono44000
by nono44000 » Fri Nov 29, 2013 5:09 pm
is it possible from the radar map view and how to move
thank you
by mediavets » Fri Nov 29, 2013 5:39 pm
nono44000 wrote:hello
Autorotation and Autotour are not the same thing.
You need to set to Autotour in Start parameters.
by mediavets » Fri Nov 29, 2013 5:41 pm
nono44000 wrote:is it possible from the radar map view and how to move
thank you
I don't understand your question.
nono44000
by nono44000 » Fri Nov 29, 2013 7:39 pm
for autorotation et autopan......
can not program 2
Start with autorotation and the latter still in operation and all les14 second exchange pano
for the 2nd problem
is it possible to get on the plane and especially on the radar and turn it so that the virtual tour through the only radar
by mediavets » Fri Nov 29, 2013 8:05 pm
nono44000 wrote:for autorotation et autopan......
can not program 2
If you want the panoramas in a tour to autorotate and to move from one scene to another after a time interval then that's what Autotour does.
If you want autorotation of a pano but no automatic progress to another pano then that's what Autorotation does.
OK?
for the 2nd problem
No, you cannot move the pano by dragging the radar with PTP 2.0.
nono44000
by nono44000 » Fri Nov 29, 2013 8:53 pm
thanks Mediavets
I want my 2 at the same time
always autorotation and all the s14 seconds
in a tour to autorotate and to move from one scene to Effective Reviews another time interval has
no good here
good night
by mediavets » Fri Nov 29, 2013 9:44 pm
nono44000 wrote:thanks Mediavets
Autotour includes autorotation.
I see no progression from scene to scene.
However it appears that PTP 2.x beta 5 does not honour the Autotour timing seting and that the interval between scenes varies very little if set to 10 seconds or to 30 seconds.
PreviousNext
