INTEGRER UN PLAN   [SOLVED] - View the solution
nono44000
INTEGRER UN PLAN
by nono44000 » Sat Nov 16, 2013 11:16 am
bonjour
comment integrer un plan ?
moi je suis allez dans floor plan mais ensuite pas la possibilite d'inserer un plan en pjg
est il possible d'avoir une notice en francais ou autres !
merci a vous
Re: INTEGRER UN PLAN  [SOLVED]
by mediavets » Sat Nov 16, 2013 11:45 am
nono44000 wrote:bonjour
merci a vous
You can have a single plan for the Project as a whole or separate plan for each Group.
In each case you select the Floorplan graphic in the Project properties panel, or the Group properties panel in the Tour section.
nono44000
by nono44000 » Sat Nov 16, 2013 5:12 pm
thank for help
nono44000
by nono44000 » Sat Nov 16, 2013 5:56 pm
comment nommer un point ?
par exemple salon
dois je ecrire dans description
thank
by mediavets » Sat Nov 16, 2013 6:03 pm
nono44000 wrote:comment nommer un point ?
par exemple salon
thank
Use the Map point hotspot tooltip field.
nono44000
by nono44000 » Sat Nov 16, 2013 6:15 pm
I like when you add a point to go a panorama
write a text
  kitchen
I do not know how?
nono44000
by nono44000 » Sat Nov 16, 2013 6:21 pm
ok thank you
but how to choose the font type or size
by mediavets » Sat Nov 16, 2013 6:24 pm
nono44000 wrote:ok thank you
At the moment, as far as I know, there is no way to do that via the GUI.
nono44000
by nono44000 » Sat Nov 16, 2013 6:43 pm
on how to create a radar map that follows the movement of the panoramic view
sorry but I'm a fan of tourwaver
and I just bought the license Panotour 2
out which is new to me
nono44000
by nono44000 » Sat Nov 16, 2013 6:44 pm
I thank you for your rapidity MediaVets for your answers
by mediavets » Sat Nov 16, 2013 7:06 pm
nono44000 wrote:on how to create a radar map that follows the movement of the panoramic view
You select and configure radars in the Map point style parameters.
nono44000
by nono44000 » Sat Nov 16, 2013 10:38 pm
I do not understand I have added the plan
but it appears not ?
radar is ok
by mediavets » Sat Nov 16, 2013 10:43 pm
nono44000 wrote:I do not understand I have added the plan
radar is ok
Did you set it to start open?
nono44000
by nono44000 » Sun Nov 17, 2013 9:24 am
it does not work!
I have the radar
nono44000
by nono44000 » Sun Nov 17, 2013 9:27 am
screen copy here
nono44000
by nono44000 » Sun Nov 17, 2013 9:31 am
voici
nono44000
by nono44000 » Sun Nov 17, 2013 9:33 am
nono44000
by nono44000 » Sun Nov 17, 2013 9:36 am
when filled description
the virtual tour that is reflected or?
by mediavets » Sun Nov 17, 2013 9:47 am
nono44000 wrote:voici
It seems odd to specify the Floorplan area size as 100% that would mean the man should cover the entire pano display area...is that your intention?
by mediavets » Sun Nov 17, 2013 9:48 am
nono44000 wrote:when filled description
If completed you can then display this using the description plugin invoked fro a button on a Control bar or via a hotspot or a Simple button plugin.
nono44000
by nono44000 » Sun Nov 17, 2013 10:45 am
I mofifie dimensions
but nothing to do
you have an online example
My plan is not working
Moreover, I realize that even in the examples of kolor no visit owns a plan
http://www.kolor.com/ptp2
nono44000
by nono44000 » Sun Nov 17, 2013 11:13 am
by mediavets » Sun Nov 17, 2013 1:04 pm
So you succeeded after all...good.
If you want to get rid of the 'container' background you can make it transparent, and you need not have the title displayed either.
If you wish to make the Floorplan work more like the old Map feature in 1.8 then you can use a Toggle or Simple button plugin to represent the closed Floorplan and have it invoke the larger Floorplan which you can optionally choose to have close with a click.
nono44000
by nono44000 » Sun Nov 17, 2013 2:26 pm
Mediavets
merci thank grazie for help
nono44000
by nono44000 » Sun Nov 17, 2013 3:06 pm
for transparent ?
