toggle button
unicityspa
toggle button
by unicityspa » Fri Nov 15, 2013 2:11 pm
is there a way to have the same position when i switch between two panoramas using toggle button? i mean ath and atv
Likes: 13 posts
Liked in: 115 posts
Re: toggle button
by bdd » Fri Nov 15, 2013 3:54 pm
unicityspa wrote:is there a way to have the same position when i switch between two panoramas using toggle button? i mean ath and atv
Directly from PTP no.
But you can do it by a little modification in the code.
In the xxx_core.xml file, copy the "mainloadscene" action, and give it the name "loadsceneandkeepview".
In this new action, replace the "MERGE" parameter in the "loadaction" call by "KEEPVIEW".
Then in the xxx_skin.xml file, find the toggle button code, and replace the 2 calls of "mainloadscene" by "loadsceneandkeepview".
unicityspa
Re: toggle button
by unicityspa » Fri Nov 15, 2013 4:19 pm
thanks it works fine
