Display log in Tour ?
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Tue Nov 12, 2013 1:00 pm
Is there a way to display KRPano log window in tour generated by PTP ? I added some extra code in XML generated by PTP to load a third party plugin but it doesn’t work and without loq it’s a lttle tricky to debug :(
Likes: 60 posts
Liked in: 169 posts
Re: Display log in Tour ?
by benji33 » Tue Nov 12, 2013 2:32 pm
You can add a "showlog();" action into XML.
For instance :
<events name="testShowLog" onTourStart="showlog();" keep="true" />
Or
You can change logkey="false" to logkey="true" into the main xml and use "o" key to open the log into the player.
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Tue Nov 12, 2013 2:46 pm
benji33 wrote:You can add a "showlog();" action into XML.
For instance :
Or
Thanks ;) might be interesting to get an option somewhere to setup it !
