Page 1 of 1
description boxes with diferent sizes
PostPosted: Mon Nov 11, 2013 2:19 am
by noupunt
I need to show descriptions with diferent box sizes from the same button... ho I can do that?
I tried to send new widht an height variables dependig on the scene to the plugin[name].settings.option[width]. the new value is correctly sended (i traced it in the logshow) but there is no change.
how can I update the box size?
thank's!
sergi
noupunt
Re: description boxes with diferent sizes
PostPosted: Mon Nov 11, 2013 5:36 am
by Destiny
Hi.. You need to add a new Description Box for each new size and then resize within the Style Tab accordingly in percent or pixels... You can use the same graphic button but you need to add it as many times as you have Description Boxes.. Then link it to a Description Box.. The problem is.. the buttons will be on EVERY pano since you cannot at this time put the button on a Pano Specific, only Tour Specific..
Not sure if this is a general bug or just a Mac bug.. but you cannot change the size of the fonts.. You can change the colour and font types... You can have overlays or not.. Radius corners and it can animate in.. or even add a url to open a web site.. or email address....
Here is a demo for you..
http://www.destinyvirtualtours.com/PTPV ... ntest.html
PostPosted: Mon Nov 11, 2013 1:00 pm
by noupunt
thank's!!
I will work on it
