Problem with the previews in full screen
phil85
Likes: 3 posts
by phil85 » Sun Nov 10, 2013 5:06 pm
A problem with the preview, every time I want to switch to full screen mode, the ball appears for a few seconds, I can handle it (not always) and then disappears, leaving me a white screen and everything freezes. I have to go through the task manager to close the Panotourpro_x64 implementation, following the forced closure of PanotourPro_x64, post the program is not responding, do you want to close, if I accept it closes all if I cancel it keeps APT open but the display of the ball in the preview disappeared (it remains Fov, Yaw, Pitch and quality).
About the quality, the problem occurs whether low, medium and hight quality .
Likes: 84 posts
Liked in: 188 posts
Re: Problem with the previews in full screen
by benji33 » Tue Nov 12, 2013 4:03 pm
What is the ball for you ?
What is your OS and version please ?
phil85
Likes: 3 posts
by phil85 » Tue Nov 12, 2013 6:04 pm
My English is a little rusty, and I use Google translation to help me in some cases.
The ball is the spherical, sorry!
My OS is Windows Vista 64 Service Pack 2.
Thanks for your help , and your great soft .
Likes: 84 posts
Liked in: 188 posts
by benji33 » Mon Dec 16, 2013 10:51 am
Problem still present with newest version ?
macalenny
by macalenny » Wed Dec 18, 2013 1:15 am
yes for me the same problem now
phil85
Likes: 3 posts
by phil85 » Wed Dec 18, 2013 6:00 pm
Hi at all
Sorry benji33 , I've a problem with my computer between two week , I'm update PT pro Saturday , give you the response this week end .
I'm install PT 2.0 pro beta5 on my portable with Win 7 and the previews in full screen works fine .
Give you the response saturday for my computer with vista 64 pack 2 .
Best regards
Likes: 84 posts
Liked in: 188 posts
by benji33 » Thu Dec 19, 2013 9:00 am
Should be solved in release of today so if happens again, add comments here.
phil85
Likes: 3 posts
by phil85 » Sun Dec 22, 2013 9:05 am
Hello !
After having repaired my tower, update PT pro 2.0 rc1 .
I redid the test and the result is the same, when I want to switch to full screen in the preview of the sphérical , the sphérical appears and when you want to make a move in the screen it goes blank or a part of the visiting image is fixed any possible move in the sphérical and block the preview in full screen mode the icons in the top left have no reaction .
I have to go through the task manager to close the " PanotourPro_x64 " window ( it tells me Panotour Pro and PanotourPro_x64 are under execution ) . After switch off the full screen preview of PT pro 2.0 rc1 via the task manager, remains only in the preview frame ( Fov , Yaw , Pitch and quality) .
I performed the tests in different qualities and the problem is identical.
Operating system : Windows Vista 64 bit sp2
Memory : 8GB
Processor: AMD Phenom 9650 Quad Core 2.4Ghz
Graphics Card: Nvidia Geforce GTS 450
On my laptop running Win 7 64 Bit it works fine !
A question : with APG3.0 , PT pro 2.0 and windows 8.1 there is no problem ?
by mediavets » Sun Dec 22, 2013 9:11 am
phil85 wrote:A question : with APG3.0 , PT pro 2.0 and windows 8.1 there is no problem ?
I have not found any problems.
phil85
Likes: 3 posts
by phil85 » Sun Dec 22, 2013 9:54 am
Ok thanks mediavets , this question because I'm going to build a new config with Windows 8.1 64bit .
Processor : i7 4770/1150/ Haswell
motherboard: asus H87M-plus
Memory : 16Go
hdd : SSD 240Go
Graphic card : Nvidia GF GT-630 / 2Go
