Сhange the quality on the mobile version ...
OlegMenkov
by OlegMenkov » Fri Nov 08, 2013 7:49 pm
is there a quality setting mobile version? (support retina ipad)
Re: Сhange the quality on the mobile version ...
by mediavets » Fri Nov 08, 2013 7:59 pm
OlegMenkov wrote:is there a quality setting mobile version? (support retina ipad)
No, there isn't.
When krpano 1.17 is finally released it will be incorporated in PTP 2.x and will then offer multi-res support on mobiles.
HansKeesom
by HansKeesom » Sat Nov 09, 2013 10:35 am
No, there isn't.
It will be so nice to be able to offer that to our customers. Zooming in on a portable device is impressive. Klaus Esser already showed us a demo of it. Very cool indeed.
http://www.360impressions.de/Medienhafen
http://www.klausesser.de/Stadthalle
OlegMenkov
by OlegMenkov » Sat Nov 09, 2013 6:20 pm
can try to modify xml files? (hack)
by benji33 » Tue Nov 12, 2013 4:35 pm
1.17 should be integrated in the next weeks with HTML5 multi-res.
You can at this time if needed use the Krpano update tools to update with the current 1.17 version of krpano for your tests. See krpano site for this manipulation with no support of Kolor while not incorporated into our product.
