start, stop background sound during video?
mime2013
by mime2013 » Fri Nov 08, 2013 9:52 am
Is it possible when I start a video in the panorama that background sound stops and starts automatically when ready?
Thank's a lot,
Michael
Re: start, stop background sound during video?
by benji33 » Tue Nov 12, 2013 3:33 pm
You're talking about the background sound of the panorama/project or the video sound ?
mime2013
by mime2013 » Tue Nov 12, 2013 4:00 pm
benji33 wrote:You're talking about the background sound of the panorama/project or the video sound ?
I want to stop the panorama sound, when I open Video and start with own sound.
When Video finished, start panorama sound again. Is this possible?
by benji33 » Tue Nov 12, 2013 4:09 pm
If video is called from a plugin or a hotspot you can add action to stop sound (Actions : Interface control > stop tour sounds).
But the start again should be done manually via a control bar for instance at this time.
mime2013
by mime2013 » Tue Nov 12, 2013 4:14 pm
benji33 wrote:If video is called from a plugin or a hotspot you can add action to stop sound (Actions : Interface control > stop tour sounds).
ok, I found this action control. this is not running, if I use an external video from youtube.
is it possible to use an internal video an have a close cross upper right? this is an important topic for my customer.
by benji33 » Tue Nov 12, 2013 4:17 pm
Better way for youtube video is to open via hotspot or plugin actions a webvideo box which have a close button.
No close button available on displayed objects (internal images and internal video).
mime2013
by mime2013 » Tue Nov 12, 2013 4:33 pm
benji33 wrote:Better way for youtube video is to open via hotspot or plugin actions a webvideo box which have a close button.
But if I use a web video in a box with close button the "stop panorama" action will not work, am I right?
Ok Benjamin, thanks a lot for your advice. Hope deeply my topics will be found in the next update. :) Your software is great, very good work!
by benji33 » Tue Nov 12, 2013 4:56 pm
mime2013 wrote:But if I use a web video in a box with close button the "stop panorama" action will not work, am I right?
You mean the "Interface control > stop tour sounds" action ? It should work if not it's a bug to report to us.
mime2013 wrote::) Your software is great, very good work!
Thank you very much.
osmica
by osmica » Wed Nov 27, 2013 9:25 am
I'm working on this also. I have a video on the TV screen and I want the tour sounds stop when video is playing. I want also a description of the video spot displays. I did what you told and this is the result. See my setings in the screenshot.
When I go to the pano, the video starts automaticly but the project background sound still playing. It stops only if I click on the menu button but that way the video sound stops also as it stop all tour sounds. When I click on the video, the description displays and the video stops. Afther that, when I click on the description it goes away (hidden) but the video still stopped. Than to continue play the video I need to click on the it again. Now the video starts but the description is visible again and afther I click on, it goes away and now finally the video still playing (without sound of course).
The biggest problem here I think it is:
1) there is missing one action "stop project,current pano or group sound" because the "stop tour sound" stops all sounds of the tour including the video spot sound (same function assigned to the sound button in the menu)
2) interaction between description spot and video spot - afther the description displays the video stops and that is OK but when I click on he description to close it, the video needs to continue playing automaticly but it is not in my case and there are no setting to change that as I can see
Thank you for your attention, regards
Toni
This are my setings for the video spot.
by benji33 » Thu Nov 28, 2013 5:14 pm
Ok reported for Description + video problem.
Sound problem (all sounds linked) was already reported.
osmica
by osmica » Thu Nov 28, 2013 6:28 pm
benji33 wrote:Ok reported for Description + video problem.
Can you just tell me what you mean "reported". Is it already fixed somehow in Beta5 or will be in next version?
Thank you!
by benji33 » Fri Nov 29, 2013 3:45 pm
No reported is into our bugs list or features list but only the change log gives you the corrected bugs or added features.
See here : http://download.kolor.com/ptp/beta/history
osmica
by osmica » Sun Jan 12, 2014 3:29 pm
OK, what's going on with this feature? Can I expect it soon or ever in future. It is a must have action I really need as soon as possible:
Action: stop background sound
I want to use it in panos where I have a video spot. I want to listen only the video sound without the background sound.
There is another better way:
In the video spot style, afther directional sound can be added a checkbox:
stop background sounds when directional sound is playing
I think all users will check it because it is disturbing when you listen 2 sound at same time. But some users will maybe want that.
This function will cover both needs. Can I expect this to be done by Kolor team?
by benji33 » Mon Jan 13, 2014 4:09 pm
Our developer work on the sound interface. So I hope a better use before the final release.
Users browsing this forum: No registered users and 8 guests
