Reset the UI
goshiota
Reset the UI
by goshiota » Thu Nov 07, 2013 9:08 am
Ugh... Does anyone know how to reset the UI to the default in the Mac version of PTP 2.0?
Thanks!
Jeremy
Likes: 84 posts
Liked in: 186 posts
Re: Reset the UI
by benji33 » Tue Nov 12, 2013 2:36 pm
Reset UI is into our todo list.
On MacOS to do it at this time, you can go tho the library with "go to + Alt" and remove the entry com.kolor.panotour or something like that. You'll have to register again the product after this task because all preferences will be lost.
goshiota
Re: Reset the UI
by goshiota » Sat Nov 16, 2013 12:28 am
Thanks, Benjamin! I could have sworn I hunted down and deleted all files and prefs related to Kolor, but alas I kept getting the same wonky interface.
I'll try as you suggested when I have a moment.
Thanks again!
Jeremy
