Modifying the tour's HTML file   [SOLVED] - View the solution
stillstonevisions
by stillstonevisions » Thu Nov 07, 2013 4:24 am
Is there a way to change the <title> line in the tour.html file. I know I can text edit it, but each time I rebuild the file, it overwrites my changes.
gabriel
Likes: 15 posts
Liked in: 13 posts
Re: Modifying the tour's HTML file
by gabriel » Sat Nov 09, 2013 12:11 am
Hi stillstonevisions,
it's normal for the overwrite, it comes from the soft, the only thing you have to do is to change the title when you have finished your tour , with a html editor, like you do.
by benji33 » Tue Nov 12, 2013 3:46 pm
Also you can make your own html template into your panotour user directories.
stillstonevisions
by stillstonevisions » Tue Nov 12, 2013 4:24 pm
Could you explain further, please. I wouldn't know how to create such a template.
Thank you,
Paul
Re: Modifying the tour's HTML file  [SOLVED]
by benji33 » Tue Nov 12, 2013 4:31 pm
1. Go into "C:\Program Files\Kolor\Panotour Pro 2.0\Resources\html" (for intance on windows) and copy one of our html template into the html directory of the Panotour user directories.
Panotour user directories can be found here : PTP > Edit > Open user directory.
2. Rename the html file to your own name. MY_HTML_TEMPLATE.html for instance.
3. Edit into a text editor the template. For instance replace the <title> content.
4. Restart Panotour
5. Open your project and into Build screen select your own HTML template. Now you can build a tour with your own HTML template.
stillstonevisions
by stillstonevisions » Tue Nov 12, 2013 4:42 pm
I understand. That should work perfectly. Thank you.
Users browsing this forum: No registered users and 10 guests
