Picture link to URL ??
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Wed Nov 06, 2013 6:45 pm
How to do a Hotspot to display a picture from an URL and not a local File ? Picture hotspot accepts only local file :( that non-sense restriction was already there in PTP 1 :O A way to do that without editing xml after each export ?
Re: Picture link to URL ??
by mediavets » Wed Nov 06, 2013 6:50 pm
vincen wrote:How to do a Hotspot to display a picture from an URL and not a local File ? Picture hotspot accepts only local file :( that non-sense restriction was already there in PTP 1 :O A way to do that without editing xml after each export ?
You could use the Web site box plugin.
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Wed Nov 06, 2013 7:04 pm
mediavets wrote:You could use the Web site box plugin.
héhé very good suggestion, just hane now to figure out how to put it in my panos ! added in style tab but don’t find how to add the spots in my panos :( probably too obvious...
by mediavets » Wed Nov 06, 2013 9:59 pm
In the Style section, add to your Workspace an instance of the type of hotspot style you wish to use to open the Website box.
Then add your hotspot in the Tour section and associate it with the Hotspot style and parameterise in Hotspot properties panel.
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Nov 07, 2013 8:41 am
mediavets wrote:Then add your hotspot in the Tour section and associate it with the Hotspot style and parameterise in Hotspot properties panel.
Thanks for details so I was correct with process ! but I don’t have the website style avalaible for hotspot :(
when I create a new hotspot, none website option !
I add here the Website box
by Destiny » Thu Nov 07, 2013 9:24 am
Vincen
You are missing a step.. After you add your Website Box Plug-in.. Then you link your Hotspot to that plug-in and provide the url.. You can choose what ever hotspot you want and the colour or even make your own custom hotspot.. Using the UI for the Website Box plug-in, you can make the Website Box any colour, give it a title, radius corners or even no boarder at all... Add the Full Screen and Exit Button...
by mediavets » Thu Nov 07, 2013 10:20 am
Thanks for details so I was correct with process ! but I don’t have the website style available for hotspot :(
Hotspot styles are multi-instance - so add a new one to your workspace and set the Action appropriately.
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Nov 07, 2013 2:45 pm
Thanks to you two, works fine now ;) Just found a limit, it’s impossible to add such hotspot on floorplan :(
Second issue is that some hotspots loose their features without reasons and unable to get them back working normally !!
by Destiny » Fri Nov 08, 2013 3:15 am
The true power of PTP V2 is the option to add other media... The issue I have is that PTP is sooo buggy with the Full Screen option.... When in Full Screen, nothing works.. I am sure its a PTP bug.. Also, its impossible to add Pano Specific Media so this is causing huge issues... It really confuses me why this feature has not been added and made as part of the main build long ago.. To do it now would mean a lot more coding and changing the way code is written.. The xml needs to be individualised as with 1.8.. As it is now, the menu and other media that I do not want on the pano are repeated.. I would also like an option to edit my menu so only those features I want on a pano are displayed..
http://www.destinyvirtualtours.com/PTPV ... nking.html
So many media types I would like to test but its the buggyness that puts a spanner into the works since it means that I have no idea whether its my media or PTP that stops things working as I want them to......
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Fri Nov 08, 2013 7:04 am
Perfect timing ;) beta 3 released yesterday and it looks to have resolved my issue with hotspots :)
by benji33 » Tue Nov 12, 2013 3:28 pm
URL should be accepted in a next release. A bug has been reported.
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Tue Nov 12, 2013 3:32 pm
benji33 wrote:URL should be accepted in a next release. A bug has been reported.
Thanks ;)
Likes: 14 posts
by bdd » Fri Nov 22, 2013 5:14 pm
Salut Vincen,
Désolé, je ne comprends pas ta requête.
L'URL c'est pour quelle partie du spot, pour quel type de spto, etc...
Le thread a dérivé sur l'affiche d'un website, mais ça n'a pas l'air d’être ton sujet d'origine.
C'est l'icone du spot que tu souhaites renseigner avec une URL ?
C'est l'image plaquée sur un "Picture spot" dans la sphere de ton panorama ?
C'est l'image qui s'affiche via l'action "Display an Image" ?
Puisque tu dis que tu modifies le code après génération, tu peux m'envoyer tes modifs, que je comprenne précisément ton besoin ?
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Sun Nov 24, 2013 11:38 am
bdd wrote:Désolé, je ne comprends pas ta requête.
Pour le problème d’url c’est résolu ;) Le seul hic qui subsiste est le fait de pas pouvoir placer sur le floorplan les hotspots personnalisés :(
by benji33 » Mon Nov 25, 2013 9:20 am
Seul les hotspots point de type map peuvent être placés sur la carte et les plans.
Ils peuvent être customisés, mais un peu moins.
