Floor Plan container background -- Floor Plan not centered
mfoleary
by mfoleary » Wed Nov 06, 2013 3:40 pm
The floor plan appears normally within its limits in photoshop and the hot spot editor; however, the background take ups to much room, and the floor plan is not centered in the container. How to reduce the background size ? How to center the floor plan in the container ? Border radius. Border margins: 0 pixel. Position. Offset: 0 pixel.
zulaica
Re: Floor Plan container background -- Floor Plan not center
by zulaica » Tue Nov 12, 2013 8:17 pm
I'm having the same issue.
Area size set to 100%, border margins at 10px, and position in the center; the floorplan map anchors to the top left. Setting the position to any other place—for example, bottom right—has no effect.
by mediavets » Tue Nov 12, 2013 8:39 pm
zulaica wrote:I'm having the same issue.
For me the map can be placed Left, Centre or Right but it appears always at the top using settings shown bleow.
PTP 2.0 beta 3 on Windows 8.1 64-bit viewing with Firefox 25.
by mediavets » Tue Nov 12, 2013 8:48 pm
mfoleary wrote:The floor plan appears normally within its limits in photoshop and the hot spot editor; however, the background take ups to much room, and the floor plan is not centered in the container. How to reduce the background size ? How to center the floor plan in the container ? Border radius. Border margins: 0 pixel. Position. Offset: 0 pixel.
Some observations:
1. You can make the container background completely transparent - see screenshot 1.
2. You need not have the map title displayed - see screenshot 1.
3. You may choose not to display a close button but instead have the Floorplan close when clicked on - see screnshot 2.
3. You can control the positioning of the Floorplan relative to the browser window edge using the Offset parameters.
Likes: 80 posts
Liked in: 182 posts
by benji33 » Wed Nov 13, 2013 10:57 am
A resize to content (very usefull) will be added later to avoid this kind of problem.
by mediavets » Wed Nov 13, 2013 12:33 pm
benji33 wrote:A resize to content (very usefull) will be added later to avoid this kind of problem.
Hurrah! Soon I hope.
bretfrk
by bretfrk » Fri Mar 14, 2014 3:52 pm
So is the floor plan position setting still a bug in version 2.0 or is there a solution?
I have one tour where it appears to work and is centered, and the second tour, it does not. Both have the same settings/pre-sets.
