add a button @ controlbar/ajouter bouton à la bar de control
gabriel
Likes: 15 posts
Liked in: 11 posts
by gabriel » Tue Nov 05, 2013 11:46 pm
Hi, i would like to add a button ( in fact a button to link to a action openwebsite ) directly into the control bar, and more, if it is possible to change the button, and the url of the function if the pano change … but begin by the beginning, how can i put a button into the control bar ? Thanks a lot …
Bonjour, je voudrais mettre un bouton ( en fait un bouton qui renvoie à la fonction openwebsite ) directement dans la barre de control, et, si c'est possible, que le bouton et la fonction change avec le pano affiché, merci d'avance
Likes: 84 posts
Liked in: 188 posts
Re: add a button @ controlbar/ajouter bouton à la bar de con
by benji33 » Wed Nov 06, 2013 1:33 pm
The only way is to copy the desired plugin control bar and update code to generate a new plugin with the new buttons. You need to know krpano code http://krpano.com/.
Some informations here : http://www.autopano.net/wiki-en/action/view/Panotour_Pro_2_Documentation
gabriel
Likes: 15 posts
Liked in: 11 posts
by gabriel » Wed Nov 06, 2013 2:49 pm
Merci Benjamin, je vais aller voir ça ...
gabriel
Likes: 15 posts
Liked in: 11 posts
by gabriel » Sat Nov 09, 2013 12:14 am
c'est cool, ça marche, merci.
