Multiple XML-Files
kitzhost
Multiple XML-Files
by kitzhost » Mon Nov 04, 2013 5:18 pm
Hello, i want to use my tour with 2 different skin-XML Files. For example:
testtour1.html uses testtour1_skin.xml and
testtour2.html uses testtour2_skin.xml
with the same images.
Or can i give a $_GET variable, for example:
http://testtour.com/tour.html?s=pano01& ... =testtour1
http://testtour.com/tour.html?s=pano01& ... =testtour2
Is there any solution?
Regards
Likes: 11 posts
Liked in: 94 posts
Re: Multiple XML-Files
by bdd » Tue Nov 05, 2013 8:35 am
kitzhost wrote:Hello, i want to use my tour with 2 different skin-XML Files. For example:
Regards
As far as we know, krpano viewer does not allow dynamic include.
If the goal, for you is to have a different skin for mobile, tablets or desktop, you can just modify the code generated by PTP in the "main" XML, and add a "device" attribute to the "include" node including the skins.
http://www.krpano.com/docu/xml/#include
http://www.krpano.com/docu/xml/#devices-notes
