Thumbnails Bar - Start Closed   [SOLVED] - View the solution
Toni Fong
Likes: 4 posts
by Toni Fong » Thu Oct 31, 2013 6:33 pm
In PTP 1.8 thumbnails bar was start closed by default and there was an option to start opened.
In PTP 2.0 thumbnails bar start opened by default but I couldn't find the option to start it closed.
Does anyone know where this option to start closed are ?
Thank you !
Toni
Likes: 79 posts
Liked in: 181 posts
Re: Thumbnails Bar - Start Closed  [SOLVED]
by benji33 » Mon Nov 04, 2013 3:39 pm
A way to do it is to change the value into "Start parameters" of the tour project to "Start tour with hideable controls hidden".
Add a control bar to display controls and thumbs when wanted.
A manual way to do it :
- change the "tour_displaythumbnails" to false into the your_tour_core.xml file
- and a control bar with show/hide thumbnails button.
Erik Dreyer likes this post.
