PTP2.0 / Livepano / issue with stitching and misalignement
Fabio Musio
by Fabio Musio » Thu Oct 31, 2013 5:47 pm
I tried to mount 2 videos on 2 separate panos following the tutorial provided by Kolor team and checking on thsi forum for any kind of improvement.
I publish at the following URL the virtual tour composed by the 2 panos: http://100digitalcreativity.com/360dc/testinglivepano/
Issue with the first pano: the video is misaligned, shifted up. On AutoPano Giga 3 (APG3) everything looked pretty well aligned.
Issue with the second pano: the video is pretty much distorted. On APG3 the screenshot was aligned pretty good and the distortion was corrected.
I have a third pano that I'm working on: in this case the issue is that I can't find a way to make APG3 to align the screenshot with the pano.
Any suggestion / recommendation?
Likes: 13 posts
Liked in: 115 posts
Re: PTP2.0 / Livepano / issue with stitching and misaligneme
by bdd » Mon Nov 04, 2013 4:15 pm
It's difficult to help you without being able to reproduce the problem you encounter.
Can you share with the support team still images from the panorama and a short extract of the video?
The procedure is explained there: viewtopic.php?f=3&t=766
Fabio Musio
by Fabio Musio » Tue Nov 12, 2013 3:20 pm
I posted the files as requested.
Where will I get a reply? Email or here?
