Floorplan points
videopixel
Floorplan points
by videopixel » Mon Oct 28, 2013 10:33 am
Is it possible to add a point on a floor plan that goes to a full-window 'normal' image instead of a panorama?
Re: Floorplan points
by mediavets » Mon Oct 28, 2013 10:57 am
videopixel wrote:Is it possible to add a point on a floor plan that goes to a full-window 'normal' image instead of a panorama?
Yes, you can mix planar projection ('normal') imsges with panoramas in a tour.
videopixel
by videopixel » Mon Oct 28, 2013 1:07 pm
Thanks for the quick reply mediavets,
If I choose planar my image is extremely zoomed in whatever setting I choose for FOV, YAW, PITCH etc. is this a DEMO-limitation?
by mediavets » Mon Oct 28, 2013 1:13 pm
videopixel wrote:Thanks for the quick reply mediavets,
Did you set the projection type?
Anyway looks like a possible bug to me, it doesn't seem to make any difference what default FOV you set on a planar image.
videopixel
by videopixel » Mon Oct 28, 2013 1:21 pm
Yes
here some screenshots:
settings:
result:
Likes: 84 posts
Liked in: 186 posts
by benji33 » Mon Nov 04, 2013 3:09 pm
Planar is not supported yet in HTML5 export. A warning exists in the build page.
