Gallery (Simple Button) display?
Dennis O'Hara
by Dennis O'Hara » Mon Oct 21, 2013 12:59 am
I have a simple button set up to show a gallery. It works when I publish the tour locally, however, after publishing to a web server using the FTP option, the button will not invoke the gallery.
When I transfer the locally published tour using an FTP program (Filezilla) the gallery button works fine.
Any ideas?
Thanks,
Dennis
Re: Gallery (Simple Button) display?
by benji33 » Mon Oct 21, 2013 2:31 pm
Do you have special chars into the images or directories files names ?
Dennis O'Hara
by Dennis O'Hara » Mon Oct 21, 2013 3:20 pm
benji33 wrote:Do you have special chars into the images or directories files names ?
What specific directories or file names should I look at?
by benji33 » Mon Oct 21, 2013 4:14 pm
Into the generated files you can have a look on "data > graphics > gallery" directories for instance.
Elsewhere do you have an url with the "corrupted" ressources ?
Dennis O'Hara
by Dennis O'Hara » Mon Oct 21, 2013 5:58 pm
benji33 wrote:Into the generated files you can have a look on "data > graphics > gallery" directories for instance.
URL with a camera icon near the control menu that doesn't work. This was FTP's by PTP 2.1
http://duluthvirtualtour.com/duluthvirtualtour.html
URL with camera icon that works to call gallery. - this was transferred by Filezilla FTP.
http://duluthvirtualtour.com/testtour/d ... ltour.html
by benji33 » Tue Oct 22, 2013 10:02 am
All the "lib" directory into duluthvirtualtourdata is missing. It's the problem.
Is it happening again after an new Panotour FTP transfert ?
If you use the project file manager see image below, is your "lib" directory red ?
Dennis O'Hara
by Dennis O'Hara » Tue Oct 22, 2013 11:34 am
Thanks for the help, I am going to cleanly re-install everything including PTP 2.1 and start from scratch. PTP is a great program and I learn something new with every step.
I will check the lib installation once things are rebuilt.
Dennis
