Add parameters to URL to start a tour with a specific pano?   [SOLVED] - View the solution
Re: Add parameters to URL to start a tour with a specific pa
by mediavets » Fri Nov 22, 2013 11:14 am
benji33 wrote:You ask about h, v, fov values ? At this time, no only the socialShare plugin return these values.
Or you can trace these values on each panorama loaded with a call to the "computeDeepLinkingURL" action which set the tour_deeplinkingvars variable with a code like this one.
<events name="returnDeepLinkingValuesEvent" onloadcomplete="returnDeepLinkingValues();" keep="true" />
<action name="returnDeepLinkingValues">
computeDeepLinkingURL();
showlog();
trace(get(tour_deeplinkingvars));
</action>
I was thinking about something more like an entry in the context menu that could be used when viewing a tour to display these values and also put them on the clipboard.
It would be basic step towards the development of a proper auto tour authoring tool....with a timeline based UI on which one places views and defines transitions and audio and so on...
Likes: 80 posts
Liked in: 182 posts
by benji33 » Fri Nov 22, 2013 1:06 pm
I add your post into the feature requests.
Previous
