Add parameters to URL to start a tour with a specific pano?   [SOLVED] - View the solution
Thomas_Demolliens
by Thomas_Demolliens » Tue Oct 15, 2013 11:43 am
Hi-
I generate my tours with PTP2. Is it possible to generate a personalised link to start the tour with a specific pano?
i.e. my tour is composed of 5 scenes and I want to create an URL to start the tour with the 2nd scene instead of the 1st one? I don't want to change the tour and the HTML file, but want to know if it is possible to add parameters to it?
Thanks for your kind answer,
Thomas
Likes: 13 posts
Liked in: 112 posts
Re: Add parameters to URL to start a tour with a specific pa  [SOLVED]
by bdd » Tue Oct 15, 2013 12:16 pm
Thomas_Demolliens wrote:Hi-
Thomas
Bonjour Thomas,
In the generated xxxdata directory, you'll find all your panorama subdirectories.
Each subdir is suffixed with the ID of the panorama.
To start to a specific panorama add the following to your tour URL : "?startscene=panoID"
You can shorten the "startscene" to "s" .
Like here for example : http://www.kolor.com/virtual-tours/2013 ... ene=pano10
Thomas_Demolliens
by Thomas_Demolliens » Tue Oct 15, 2013 12:21 pm
Bonjour Gérald,
Many thanks, it works great, I only replaced the panoID by the scene name.
Encore merci!
Thomas
Thomas_Demolliens
by Thomas_Demolliens » Tue Oct 15, 2013 12:43 pm
I guess it is then also possible to change the parametres of the default hlookat value?
I've tried different combinations and none of them work...
tour.html?startscene=xxx?vlookat=xxx
tour.html?startscene=xxx,?vlookat=xxx
Any suggestion?
Likes: 80 posts
Liked in: 182 posts
by benji33 » Wed Oct 16, 2013 9:05 am
Parameters are :
param. = value
startscene (or s) = scene name ID
h = hLookAt value
v = vLookAt value
f = fov value
sample :
Your_URL.html?s=pano1&h=132&v=-22&f=90
Also documented here.
Annis likes this post.
Thomas_Demolliens
by Thomas_Demolliens » Wed Oct 16, 2013 10:51 am
Many many thanks Kolor Team, but it doesn't work...
Frenchev
Liked in: 3 posts
by Frenchev » Thu Oct 24, 2013 11:36 pm
Hi, is this "?startscene=panoID" working on tours build with PTP 1.8? If not, is there an other way, to do it on tours build with 1.8?
And where can I find the panoID?
Thank you very much.
P.S. Please excuse my terrible English.
by mediavets » Fri Oct 25, 2013 9:16 am
Frenchev wrote:Hi, is this "?startscene=panoID" working on tours build with PTP 1.8?
No.
See: http://krpano.com/plugins/userplugins/swfaddress/#top
Not relevant if you are using PTP 1.8.
Arnim
by Arnim » Thu Nov 14, 2013 12:19 pm
I'm using Panotour 2.0beta3 (not Pro) - and I'm not able to get the Parameters working.
Do I have to use the Pro Version? Or what could be wrong?
Arnim.
by mediavets » Thu Nov 14, 2013 12:34 pm
Arnim wrote:I'm using Panotour 2.0beta3 (not Pro) - and I'm not able to get the Parameters working.
Arnim.
Welcome to the forum...
How are you determining the PanoID?
See: ucp.php?i=pm&mode=compose&action=quotepost&p=128762
Likes: 80 posts
Liked in: 182 posts
by benji33 » Thu Nov 14, 2013 1:00 pm
Into PT and PTP when you select a panorama on the properties panel (on right) there is an information (i) icon next to the panorama name which inform you on the panorama ID to use.
Arnim
by Arnim » Thu Nov 14, 2013 2:57 pm
@benji33: I'm not able to locate the Information-Panel you are talking about. There is no (i) anywhere in the "Properties".
@mediavets: I just looked at the generated subfolders and took the postfix i.e. 70 for folder "Lounge_2_70".
You can find the panos here: http://dein-mietstudio.de/raeume/panoramaeinsicht
I tried
- http://dein-mietstudio.de/raeume/panora ... x?s=Pano61
- http://dein-mietstudio.de/raeume/panora ... .aspx?s=61
Doesn't seem to work or a I going in the wrong direction?
Thanx, Arnim.
by mediavets » Thu Nov 14, 2013 2:58 pm
Arnim wrote:@benji33: I'm not able to locate the Information-Panel you are talking about. There is no (i) anywhere in the "Properties".
Arnim.
See screenshot below:
Arnim
by Arnim » Thu Nov 14, 2013 3:09 pm
@mediavets: As I told you - I don't have that button. Maybe its a PRO feature?
by mediavets » Thu Nov 14, 2013 3:14 pm
Arnim wrote:@mediavets: As I told you - I don't have that button. Maybe its a PRO feature?
Did you select a pano thumbnail in the main panel - to the left side - to open the panorama properties panel on the right side?
Hellkeeper
by Hellkeeper » Thu Nov 14, 2013 3:15 pm
I got a Question to this functionality ... we used swfAddress in V1.8 - and are now in the process of switching to 2.0 Beta.
How can we achieve that the URL will be updated with actual Image-Call like with swfAddress? (so someone can copy/paste URL to get to the viewed Image)
(using PRO Version)
Thank you
Andreas Schnederle-Wagner
Likes: 80 posts
Liked in: 182 posts
by benji33 » Thu Nov 14, 2013 3:18 pm
Ok I'm sorry, I've answered too quickly, it's a Panotour Pro feature. Deep linking and (i) button are available only into the Pro version. It's why it doesn't work with your Panotour Standard edition visit.
Arnim
by Arnim » Thu Nov 14, 2013 3:29 pm
Deep linking is the Feature I'm looking for - correct? :-(
Likes: 80 posts
Liked in: 182 posts
by benji33 » Thu Nov 14, 2013 3:30 pm
Hellkeeper wrote:Hi,
(using PRO Version)
Thank you
Hi, I don't know the functionnality of this plugin but you can have a look into the YOUR_TOUR_core.xml file and look after the computeDeepLinkingURL action which generate the PTP deep linking string into the tour_deeplinkingvars variable. This variable can be added to your url with krpano string operator txtadd.
Likes: 80 posts
Liked in: 182 posts
by benji33 » Thu Nov 14, 2013 3:31 pm
Arnim wrote:Deep linking is the Feature I'm looking for - correct? :-(
Yes, usage of startscene or s, fov, h, v to go to a specific panorama at a specific position.
Hellkeeper
by Hellkeeper » Thu Nov 14, 2013 3:36 pm
benji33 wrote:Hi, I don't know the functionnality of this plugin but you can have a look into the YOUR_TOUR_core.xml file and look after the computeDeepLinkingURL action which generate the PTP deep linking string into the tour_deeplinkingvars variable. This variable can be added to your url with krpano string operator txtadd.
I'm not sure how/where I can manipulate the URL. How would I implement that the URL changes to pano.html?s=panoID when clicking on a Link within the Tour? (guess this needs to be implemented with anchors like swfAddress - so the whole page won't get reloaded?)
Example: http://in.futureweb.at/temp/panotour_ki ... ch_hinten/ --> click on linking within the Pano and look at the URL (always links to the shown picture of the Tour)
Thank you
Andreas
Hellkeeper
by Hellkeeper » Wed Nov 20, 2013 4:42 pm
anyone?
Likes: 80 posts
Liked in: 182 posts
by benji33 » Thu Nov 21, 2013 9:26 am
Impossible at this time but into the feature requests. swfAddress can be used I think, not tested.
by mediavets » Thu Nov 21, 2013 6:41 pm
benji33 wrote:Parameters are :
param. = value
h = hLookAt value
v = vLookAt value
f = fov value
sample :
Is there a simple way to determine these parameters for any particular pano view?
Likes: 80 posts
Liked in: 182 posts
by benji33 » Fri Nov 22, 2013 10:42 am
You ask about h, v, fov values ? At this time, no only the socialShare plugin return these values.
Or you can trace these values on each panorama loaded with a call to the "computeDeepLinkingURL" action which set the tour_deeplinkingvars variable with a code like this one.
<events name="returnDeepLinkingValuesEvent" onloadcomplete="returnDeepLinkingValues();" keep="true" />
<action name="returnDeepLinkingValues">
computeDeepLinkingURL();
showlog();
trace(get(tour_deeplinkingvars));
</action>
