can´t architectural view be as default?
by klausesser » Sun Oct 13, 2013 5:30 pm
Hi!
I usally use "architecturalview" as projection. I can´t manage to set it as
default - don´t need other types of projection at all.
I can´t get "autotour" to be "auto" in a way i understand "autotour" - an automatically
running tour. What does "autotour" mean anyway?
Re: can´t architectural view be as default?
by mediavets » Sun Oct 13, 2013 5:38 pm
klausesser wrote:I can´t get "autotour" to be "auto" in a way i understand "autotour" - an automatically
It means it progresses automatically from panorama/scene to panorama/scene.
You need to have the Autotour button enable on your Control bar.
And if you wish to have the Autotour enabled at the start then you need to set that in Project properties/Start parameters.
1- ptp2b1-autotour.jpg (174.18 KiB) Viewed 978 times
2- ptp2b1-autotour.jpg (132.23 KiB) Viewed 978 times
by mediavets » Sun Oct 13, 2013 6:12 pm
klausesser wrote:Hi!
I don't think there's an option to set that via the GUI.
You may like to propose it as a feature request.
Likes: 80 posts
Liked in: 182 posts
by benji33 » Mon Oct 14, 2013 9:34 am
Yep this is added as feature request.
by klausesser » Mon Oct 14, 2013 3:52 pm
Thx, Andrew and benji!
fotojehle
by fotojehle » Tue Nov 05, 2013 11:26 am
The same I wanted to post too.
Can be clickable option in the view settings.
Felix
