Full screen doesn't want to be my friend.
Octavias
by Octavias » Mon Oct 07, 2013 6:21 pm
Hey guys, i have a bit of a problem.
Since i started working in ptp 2.0 some of my tours wont go full screen for some reason. I use Pano Press plug in for wordpress and i can't figure out what the problem is.
http://www.acmbphotography.com/virtual-tours/ the initial tour that opens up was done in Alpha 9 i think and still works with a full screen button. but this new one that i just posted doesn't http://www.lisolanyc.com/virtual-tour/
Can anyone suggest where i went wrong? is it the Pano Press settings or the way i am exporting the tours?
Thanks!
Re: Full screen doesn't want to be my friend.
by benji33 » Tue Oct 08, 2013 8:21 am
In fact <iframe> integration need a new attribute. You have to add the "allowfullscreen" attribute into the iframe tag. I don't know if PanoPress is able to do it.
Example :
<iframe width="100%" scrolling="no" height="550" frameborder="0" class="iframe-class" src="http://www.lisolanyc.com/vt/Lisola.html" allowfullscreen></iframe>
If you're using HTML5 plugins as PdfBox, PanoramaMenu or Gallery, the fullscreen use the HTML5 API which can be called only if allowfullscreen is added into <iframe> attributes.
Octavias
by Octavias » Tue Oct 08, 2013 11:43 pm
Thank you so much!!!
It worked like a charm
