Editeur sans limite de taille pour poser au mieux les verticales
Panorama
by Panorama » Tue Jun 24, 2008 3:56 pm
Dans certains cas, ça pourrait être bien utile d'avoir la possibilité de visualiser l'image à  100% pour se rendre compte que certaines lignes verticales sont pas droites ... puis pour tracer les lignes verticales avec le maximum de précision.
cordialement,
Panorama
leedsjoe
by leedsjoe » Tue Jun 24, 2008 5:09 pm
You seeing I am replying in English.
If I have understood your French, you may find this helpful. At the bottom left of the visualisation window, in the Pano Editor, is a drop-down list which has settings, for magnification, between 6.25% and 800%.
Hope this is relevant and helps.
DrSlony
by DrSlony » Tue Jun 24, 2008 6:10 pm
Change the size of the preview render in Settings to something big if you do not have any big perpendicular objects, for example to 3200px wide, this will make the preview higher resolution, then zoom in to 100% or 200%, set verticals, hit ok, and once it reprojects the pano, change the preview back to something small like 800px or 1200px wide so that working on the pano will not take a long time to reproject with every change you make.
leedsjoe
by leedsjoe » Tue Jun 24, 2008 6:54 pm
Dr Slony: thanks for this - I hadn't thought of the need to get a better resolution as well.
To add to this joint effort, the route to making the change of Settings is, in the APP main Window:
Edit | Settings | Editor | Preview Quality: Size - the maximum values, as recommended, are 3200 x 1600.
by GURL » Tue Jun 24, 2008 9:05 pm
Alexandre described APP-2 GPU processing as a solution for faster and larger previews: "GPU processing at every level, that will enable real-time visualization in the panorama editor, at full resolution"
Alexandre a presenté l'utilisation des GPU (carte graphique) dans la future version d'APP comme le moyen d'avoir des prévisualisations plus détaillées et plus rapides. Comme il a parlé de temps de réponse divisé par 20 ça risque d'alléger considérablement l'utilisation de l'éditeur!
http://www.autopano.net/blog/2008/06/17/kolor-announces-autopano-2-20-new-features-nouveautes-autopano/
