Installer visite virtuelle 360° x 180° sur Ipad en local
Ivan38
by Ivan38 » Mon Nov 18, 2013 1:58 pm
Est-il possible et si oui comment, d'installer une visite virtuelle issu de ptp 1.8 ou ptp2.0beta en local sur un Ipad ?
capotondi
Re: Installer visite virtuelle 360° x 180° sur Ipad en local
by capotondi » Mon Dec 02, 2013 7:44 pm
with panotour pro 2.0 yes
you just need a file manager app on the ipad and then transfer a zip file using itunes.
i personally use "filemanager"
Before to do this it could be a good idea to remove the desktop and mobile folders from the panos folders.
You can also delete desktop/tablet and then rename the mobile folder to tablet, it would be much faster and light but of course you'll loose some quality.
Best Regards
Ivan38
by Ivan38 » Tue Dec 03, 2013 8:40 am
Merci beaucoup pour votre réponse,
Cordialement,
