Editing NADIR shots WITHOUT Photoshop
All things panoramic.
Californian
by Californian » Fri Jul 31, 2009 6:13 am
Has anyone tried to get rid of the tripod legs on NADIR shots using a software other than Photoshop? I've decided to live without Photoshop to promote independent, smaller software makers instead... (I apply the same concept to Hollywood movies but that's for another post...hmmm another forum even :cool: )
Anyone using Nikon Capture NX2?
I guess the alternative would be to shot the NADIR:
- without tripod with the challenge to position the camera at same height as when on the tripod
- with a tripod but with a center column positioned horizontally
What do you guys think?
Thanks a lot in advance for your feedback: it's much appreciated.
Paul
by Paul » Fri Jul 31, 2009 7:23 am
free software:
- Paint.Net
- Gimp
nadir in bottom layer, rotating, resizing, retouching ...
Paul
Ronald Tichelaar
by Ronald Tichelaar » Sun Aug 02, 2009 5:05 pm
Hi Californian,
I patch the nadir in APP. This is my workflow...
I shoot a 360º in 10 fisheye exposures. 6 Around the horizontal axis at a 60º interval, 1 zenith image, 2 nadir images 90º rotated, finally 1 holding the tripod at 45º over the area where the tripod stood, camera pointing down for the patching image.
Use any photo editor that supports alpha-channels and create an alpha-channel (mask) over the tripods of both nadir shots. Also create an alpha channel over the whole patching image except the area where the tripod stood.
Save images as tiff with alpha-channel and load them into APP.
Detect without lens-correction. Open the Control Points Editor and remove all the links from the patching image to the other images. Create new CPs for the patching image and one of the nadir images, create them as close to the tripod-footprint as possible.
Now optimize with lens-distortion and advanced-distortion. Remove bad CPs, create new CPs if necessary. Optimize again.
Finally for the last optimization, use Local Optimize on the patching-image. Next, use color-correction, straighten the pano and render.
Ronald
Fujifilm S5 Pro, Nikon D300, NodalNinja 3mk2, Sigma 10mm f/2.8 fisheye HSM,
Sigma 30mm f/1.4 EX HSM, Sigma 24-70 f/2.8 EX HSM, Sigma 70-200mm f/2.8 EX HSM
Californian
by Californian » Sun Aug 02, 2009 6:03 pm
Thank you SO much for your time and the thoroughness of your post. This is helping me a lot.
digipano
by digipano » Sun Aug 02, 2009 6:43 pm
Great tutorial I would say that this should become part of the official wiki (help pages) which is lacking in many areas.
trondk
by trondk » Sun Aug 02, 2009 10:14 pm
I use Pixelmator for Mac OS X for editing. It is a great app and definitely worth usd 59. http://www.pixelmator.com/
Take a look at the specs: http://www.pixelmator.com/specs/
Trond Kristiansen
Sony NEX-5, Rokinon 8mm fisheye, NN R1
Nikon D80, Nikkor 10.5mm fisheye, 18-135 kit lens, NN5L w/RD-16
iMac 24"; Macbook Pro 17"; APG and PTP
UK Pano
by UK Pano » Sun Aug 02, 2009 10:37 pm
Ronald thank you also for a superb and detailed explanation! I've read about using alpha masks over on the panoguide forum but never figured out how to apply with APP - until now!
Ronald Tichelaar
by Ronald Tichelaar » Sun Aug 02, 2009 11:50 pm
@all, glad to be of help, if you need any help don't hesitate to ask.
@trondk, Hi! thank you for pointing out Pixelmator. I've heard about the application but never gave it much attention until now. Unfortunately they don't support 16-bit yet, maybe in the future. Until then I'll keep a close watch on them.
Ronald
Paradise33
by Paradise33 » Mon Aug 03, 2009 4:45 am
The patch tool in Pano2VR software is well worth looking at for editing the nadir - in my case applying a mirrorball/logo. I was using Photoshop but this is much more streamlined way of doing it.
DrSlony
by DrSlony » Sun Dec 11, 2011 11:10 am
Gimp + Mathmap. Free (as in beer and speech) and powerful.
Extract the nadir from the 360°x180° equirectangular pano using this Mathmap script:
filter ToNadirZenith (image in)
# Filter created by Seb Przd
# Licensed under the GPL
if x<0 then
sinphi1=1;
xx=x+X/2;
else
sinphi1=-1;
xx=x-X/2;
end;
yy=y;
rr=sqrt(xx^2+yy^2);
c=atan(rr/Y);
phi =
if rr == 0 then
 0
else
 asin(cos(c)*sinphi1)
end;
xxx=atan(xx,-yy*sinphi1)*X/pi;
yyy=phi*Y/(pi/2);
in(xy:[xxx,yyy])
end
Fix the nadir using the "clone brush", "heal brush", and "heal selection" (intelligently regenerates the selected part based on the edges).
When done, inject the nadir back into the equirectangular pano:
filter FromNadirZenith (image in)
output=1;
if y>Y/4 then
sinphi1=1;
xc=-X/2;
else if y<-Y/4 then
sinphi1=-1;
xc=X/2;
else
 output=0;
end;
end;
cosc=sinphi1*sin(y/Y*pi/2);
xx=cos(y/Y*pi/2)*sin(x/X*pi)/cosc;
yy=-sinphi1*cos(y/Y*pi/2)*cos(x/X*pi)/cosc;
if abs(xx)>1 then output=0; end;
if output then
in(xy:[xx*X/2+xc,yy*Y])
else
rgbaColor(0,0,0,0)
end
end
Maukoop.nl
by Maukoop.nl » Sat Dec 24, 2011 2:38 pm
KR Pano has this droplets which I put in my dock. Drop the spherical images on this, and it converts it to cube-faces. This cube-faces I can handle in PS, but I am trying to do it as Ronald suggested, with an extra shot 45 degrees and alpha channels.
sidkarora
by sidkarora » Wed May 23, 2012 4:29 pm
Thats really a gud idea for it...but one of my concern is of indoor panorama. In the house the floor pattern should be patched seemlessly and that is where I'm getting more problems. Do you have some idea for that?
by klausesser » Wed May 23, 2012 5:07 pm
sidkarora wrote:Do you have some idea for that?
Yes - be precise while patching it in Photoshop. ;):cool: It works better the smaller your Nadir-hole is.
Therefore take care when you shoot - keep the tripod-legs narrow and use -12° for the horizontal row with a 180° fisheye.
I use to shoot 6 hor @-12° and one Zenith with a fullframe and 15mm fisheye. But you also can do it using a DX and 10,5mm taking -10° hor. and one Zenith.
I never need to shoot a Nadir - neither fullframe nor DX.
Nadir and pano: http://www.360impressions.de/Schadowplatz/ (unused version)
by AlexandreJ » Wed May 23, 2012 5:09 pm
Awesome post Ronald Tichelaar ! Thanks for doing that.
eudanck
by eudanck » Mon Nov 26, 2012 12:27 pm
Hi everyone,
I cut in photoshop and saving to TIFF with transparency, but when i import the imgs, transparent spaces ... turn white when rendering, missing some setting so that it is transparent ?
tnks
eudanck
by eudanck » Tue Nov 27, 2012 12:42 pm
Hi tnkhs for answer !
See here my screens:
And here with checks:
tnks
eudanck
by eudanck » Wed Nov 28, 2012 1:48 am
gkaefer wrote:
eudanck wrote:Hi tnkhs for answer !
http://www.adilsonborges.com.br/lixo_/tela1.jpg
http://www.adilsonborges.com.br/lixo_/tela2.jpg
tnks
posting one and the same posting & images on three different places does not make sense...
(I will delete my post in 24 hours... )
Sorry that, but you can help me ? tnks
by gkaefer » Wed Nov 28, 2012 6:00 pm
tnks
not really.
1. do you have the images in PS saving it with transparency and now importing to autopano you have no transparency?
or
2. do you create your pano and wanna save it with transparency and wen opening the layered pano in PS you have no tranparency?
in case of 1. does this help: http://www.autopano.net/wiki-en/action/view/Why_is_the_transparant_part_black%3F ?
eudanck
by eudanck » Wed Nov 28, 2012 6:13 pm
1 - No, i have photo of NADIR with tripod and cut this tripod area in PS, then save this img to TIFF with alpha channel but when import in autopano giga this nadir apper like imgs in my last post;
2 - I try export in .PSD to edit layers and erase tripod in PS.
Tnks !!!
by gkaefer » Wed Nov 28, 2012 7:30 pm
eudanck wrote:1 - No, i have photo of NADIR with tripod and cut this tripod area in PS, then save this img to TIFF with alpha channel but when import in autopano giga this nadir apper like imgs in my last post;
Tnks !!!
ok. understand. following screenshot gives you the solution why the layers is not possible to activate in your screenshot above...
select psd output so "embedd all output" can be activated
split in the Layers window your images to more than one Layer. I did for testing move one image to this layer (and disabled it so you can see the "disabled" image location in pano preview... by creating a second Layer and moving one image to the new Layer the "Layers" option can be activated in the render settings...
eudanck
by eudanck » Wed Nov 28, 2012 7:59 pm
IS THAT !!! Thankyou very much !
But my TIFF dont have transparency, you see in my img ? But when i onpen this same TIFF in PS or GIMP the hole transparent is there !
jackmarknow
by jackmarknow » Wed Jan 16, 2013 7:49 am
__________________
WoW Gold|D3 Gold|RS Gold
