Is there a solution to edit an old post subject? I would like to change a subject in one of my posts, because a bug was solved in next release, but I can not find an option to do this...
Rafal Canon EOS 400D, Sigma 10mm F2.8 EX DC fisheye, Panosaurus, Intel Xeon E3110, OCZ 8GB PC1066 CL5 Reaper EPP, Asus P5Q Deluxe, ZOTAC 9800 GTX+ AMP! EDITION, Windows XP Pro x64 Edition /// my pano work: htpp://www.expo360.pl
r--x wrote:Is there a solution to edit an old post subject?
Not AFAIK - other than asking a moderator to change it.
Andrew Stephens Many different Nodal Ninja and Agnos pano heads. Merlin/Panogear mount with Papywizard on Nokia Internet tablets. Nikon D5100 and D40, Sigma 8mm f3.5 FE, Nikon 10.5mm FE, 35mm, 50mm, 18-55mm, 70-210mm. Promote control.
AlexandreJ wrote:Normally, every author can edit his own post ( edit bouton right bottom to the text thread ).
But not the subject line of the thread - which is what the OP wished to do - even if you are the person who initiated the thread.
