Decrypt XML files
All things panoramic.
gia_czilla
Decrypt XML files
by gia_czilla » Thu Apr 19, 2018 1:05 am
I found a post asking about whether it is possible to decrypt XML files generated from Panotour Pro. It was posted in 2016, and the answer was a no. I was just wondering if this is still the case or if someone has found a way to decrypt them to further modify the code (e.g. hotspots). If not, is there a way to edit Panotour files using Kr Pano?
Thanks!
Link to previous post re: decrpyting xml files
http://www.kolor.com/forum/viewtopic.php?f=92&t=30001&p=177505&hilit=decrypt#p177505
Clément_S
Liked in: 6 posts
Re: Decrypt XML files
by Clément_S » Fri Apr 20, 2018 1:58 pm
The XML files generated by the trial version of Panotour Pro are encrypted on purpose. If you want to edit those files you will need to buy a Panotour Pro license, there's no workaround.
Best,
Clément - Kolor team
