Offline hosting for VR Headsets
All things panoramic.
Peter Stephens
by Peter Stephens » Mon Apr 09, 2018 2:03 pm
What's a good way to run virtual tours offline for use on VR Headsets at expos etc...? I've read that the Panotour Viewer is quite basic and "not intended for commercial use." What other options are there ?
Cheers,
Peter
Toni Fong
Likes: 4 posts
Re: Offline hosting for VR Headsets
by Toni Fong » Fri May 11, 2018 6:01 pm
Anyone got a solution for this ? Offline tours in expo using headsets, mostly Gear VR now, are a must, why Kolor don't make a solution for this ? PTV dissapeared from play store.
mycharmingvietnam
by mycharmingvietnam » Fri Jun 01, 2018 2:34 am
I'm facing the same problem, PTV dissapeared from my play store without any notice. Does anyone has solution for this?
My Perfect iso cool pillow PC Build to handle projects: Macbook Pro, xtreme comfort 13 inch, 256 Gb RAM, PharMeDoc, NVDIA snuggle pedic body pillow A sleep can't be good without a best memory foam pillow
Clément_S
Liked in: 6 posts
by Clément_S » Fri Jun 01, 2018 8:03 am
Thank you for your feedback. Panotour Viewer is indeed not available on the Google Play Store currently. We're working to put it back online as soon as possible, sorry for the inconvenience caused.
Best,
Clément - Kolor team
