Resolution for VR Tours
All things panoramic.
view360
Liked in: 3 posts
by view360 » Fri Jun 23, 2017 5:46 pm
Dear All, I am creating VR versions of my tours for various clients. I supply a generic VR headset that is suitable for most phone types. The quality of the image when viewing is not very sharp or clean. Can anyone advise what resolution (dpi) I should be creating my panoramas, to get the best possible image when viewing using a VR headset. Many thanks,
John
Re: Resolution for VR Tours
by klausesser » Mon Oct 16, 2017 6:53 pm
view360 wrote:Dear All, I am creating VR versions of my tours for various clients. I supply a generic VR headset that is suitable for most phone types. The quality of the image when viewing is not very sharp or clean. Can anyone advise what resolution (dpi) I should be creating my panoramas, to get the best possible image when viewing using a VR headset. Many thanks,
John
Your pan should be at least 20000x10000px for vr or more.
I usually use about 47806 × 23903:
http://klausesser.de/Katharina_Grosse/index.html
http://www.klausesser.de/En_Vie/index.html
In the end it´s a question of what you really need - when your content has many fine details higher resolution is preferable.
It also depends on the headset - some are rather hires!..
view360
Liked in: 3 posts
by view360 » Mon Oct 16, 2017 7:18 pm
Hello Klaus, thank you for your reply. Is an image with such high resolution not too large a file. Currently I use 6000 x 3000 with a file size of around 2.5mb. I note an example for your perusal. http://www.view360online.co.uk/Manorvie ... index.html
Do you have any particular preference on a headset I could recommend my clients? I quite like the Homido V2. Regards, John.
by klausesser » Sat Oct 28, 2017 12:58 pm
view360 wrote:Do you have any particular preference on a headset I could recommend my clients? I quite like the Homido V2. Regards, John.
Hi John!
As minimum data-resolution i suggest 10000x5000px. You´ll never know which device somebody has.
I test my content on Oculus and some smartphone gadgeds. Using an iPhone 6 - or another phone in that range - it works absolutely great! In this case i suggest to have 20000x10000px data.
