360 panorama stitching
All things panoramic.
LBernos
Likes: 47 posts
Liked in: 7 posts
by LBernos » Wed Sep 21, 2016 12:33 pm
Hello!
Apologies for asking about this, i know there is a big chance this question is on the forums, but I have spent time looking for it but I cannot find any threads regarding on this.
I have 360 Panorama project and I am wondering if I can edit a 360 pano on a APG or any kolor software? I do the 360 pano stitch on GigaPan stitch software, but you cant do so much in it..
thank you guys!
Lino
360PRO
Liked in: 3 posts
Re: 360 panorama stitching
by 360PRO » Wed Sep 21, 2016 1:30 pm
Hi, I think the APG software is a lot more intuïtive and gives you more possibillities. For example, if the stitch is not good, you can always improve the control points (RMS >3 is good) or just choose the overlap from a different camera. If these things don't work you have a couple of extra possibillities. And worst case scenario (if I completely fucked up) I use after effects after the stitch (or photoshop).
But APG is a standard stitching program for our company
LBernos likes this post.
LBernos
Likes: 47 posts
Liked in: 7 posts
by LBernos » Wed Sep 21, 2016 1:33 pm
360PRO wrote:Hi, I think the APG software is a lot more intuïtive and gives you more possibillities. For example, if the stitch is not good, you can always improve the control points (RMS >3 is good) or just choose the overlap from a different camera. If these things don't work you have a couple of extra possibillities. And worst case scenario (if I completely fucked up) I use after effects after the stitch (or photoshop).
Thank you for your reply!
Actually I was trying all day to do a 360 panorama via APG, but it seems I cant do it. DO you know any links of tutorials regarding the process of stitching 360 panoramas?
Thank you
Lino
360PRO
Liked in: 3 posts
by 360PRO » Wed Sep 21, 2016 2:10 pm
LBernos
Likes: 47 posts
Liked in: 7 posts
by LBernos » Wed Sep 21, 2016 2:13 pm
360PRO wrote:https://www.youtube.com/watch?v=DNKf0QJYnzU
Try this one, hope it helps
Hi!
Does that tutorial also work for images? because my project now is 360 panoramas from images...
thank you!
Lino
360PRO
Liked in: 3 posts
by 360PRO » Wed Sep 21, 2016 2:30 pm
first part is apg, second is avp (first photo then video :) )
LBernos
Likes: 47 posts
Liked in: 7 posts
by LBernos » Wed Sep 21, 2016 2:38 pm
360PRO wrote:first part is apg, second is avp (first photo then video :) )
Thank you! sorry I am on the road so I cannot view the whole video. thanks for your help :)
One more thing.. while shooting a 360 panorama, how do you deal with the nadir? I mean do you take a separate photo of the floor then patch it later?
360PRO
Liked in: 3 posts
by 360PRO » Wed Sep 21, 2016 3:00 pm
In panotour you can cover the nadir hole by uploading a .png file. just as easy as that (you can make it bigger or smaller later on). Also you can use different patches/panorama. was convenient for me to cover multiple stores.
LBernos
Likes: 47 posts
Liked in: 7 posts
by LBernos » Wed Sep 21, 2016 3:10 pm
360PRO wrote:In panotour you can cover the nadir hole by uploading a .png file. just as easy as that (you can make it bigger or smaller later on). Also you can use different patches/panorama. was convenient for me to cover multiple stores.
Hello!
Could that .png file the same as the flooring where my tripod stood? I mean, need to make it blend so like the camera was just floating there. sorry, my words are a little confusing but I am sure you know what I mean. :)
How do you suggest I do that?
Thanks man... youre a big help
Lino
LBernos
Likes: 47 posts
Liked in: 7 posts
by LBernos » Wed Sep 21, 2016 3:55 pm
never mind I already found out :) thank you so much for your help man. I truly appreciate it.
Lino
by gkaefer » Fri Sep 23, 2016 12:10 am
you mentioned gigapan in above posting. you can use the gigapan importer in APG so the correct alignment supports the stitching process...
LBernos
Likes: 47 posts
Liked in: 7 posts
by LBernos » Sat Sep 24, 2016 11:52 am
gkaefer wrote:you mentioned gigapan in above posting. you can use the gigapan importer in APG so the correct alignment supports the stitching process...
Thank you!
