Panotour Next / Prev scenes
All things panoramic.
GiovanniFerraro
by GiovanniFerraro » Sat Sep 17, 2016 10:36 am
how to exclude scenes from Next / prev plugin?
Thank you
Re: Panotour Next / Prev scenes
by Destiny » Sat Sep 17, 2016 10:38 am
Plugin Library > Controls...
Defaults or make your own..
GiovanniFerraro
by GiovanniFerraro » Sat Sep 17, 2016 10:44 am
sorry..
can you explain more clearly ..
Thank you
by Destiny » Sat Sep 17, 2016 10:53 am
There are 3 default options.. Just add the Plugin that you would like to use.. Or you can make your own styles. You can order your panos in the Tour tab, so the Next Pano will be as you have set them.. Same with the Previous pano.....
You can also group your panos.. You can only use one style of Previous or Next Plugin.. There are parameters you can set including colour..
You can also use the Menu Previous and Next Pano. Again, these will display according to how you have arranged them in the Tour tab..
GiovanniFerraro
by GiovanniFerraro » Sat Sep 17, 2016 11:03 am
..I would want to skip some scenes .. excluding from the next function / perv .. as having three scenes, we press I go next scene 2, yet I go next scene 1, excluding the scene 3.
Thank you
by Destiny » Sat Sep 17, 2016 11:18 am
Are you saying that your scene 3 does not open after scene 2.. Is it a full pano...
momocoua
by momocoua » Thu Sep 22, 2016 8:48 am
I was also interested in a solution to this situation.
I used the tour video transitions.
How to exclude them from the view on the buttons Next / Prev scenes
Thank you
by Destiny » Thu Sep 22, 2016 9:41 am
Hi.. Gerald send me how to do it info..
"Create groups containing a "main" scene, the first one, and derivative ones (the phantom ones).
  In  Prev/Next features, use Prev/Next group action instead of Prev/Next scene action.
  And in each scene use hotspots, that leads only to the main scene of each group.
  But in this main scene, use some hotspots that leads to the phantom ones."
This is my test, it works.. =D http://www.destinyvirtualtours.com/Phan ... mTour.html
Basically, I have 7 panos, but only 4 will be available using the Next and Previous.
momocoua
by momocoua » Thu Sep 22, 2016 10:30 am
It is interesting. GROUP I tried but there is a problem you can not use the video transfer to a specific panoram.
I have made a tour in it 4 panorama and 4 video transition
I want to have a Next / Prev only 4 panorama and all
momocoua
by momocoua » Fri Sep 23, 2016 6:07 am
Thank you all for your advice and help. Invented panotour decision means really long time to do but it works.
