Autopano and Lightroom - file size to large
All things panoramic.
Arnason
by Arnason » Fri Sep 07, 2007 8:42 pm
I am a new user of Autopano. I have encountered that once I have created a tiff image and want to edit it further in Lightroom the file size ( in my case 140 mb from 6 raw files out of Canon D20) is way to large for Lightroom.
Can somone come up with a suggestion how I should solve this problem. I am creating tiff images for printing so jpg conversion would not be a suggestion in my case.
ThomasPF
by ThomasPF » Sat Sep 08, 2007 5:44 am
I think you should make it the other way, first Lightroom than APP.
Or use Photoshop for the postprocessing after rendering.
I use LR--> APP-->PS
Thomas
BeeZed
by BeeZed » Sat Sep 08, 2007 6:01 am
Lightroom has a maximum pixel limit of 10,000, so larger panos will not load. (See http://luminous-landscape.com/forum/lofiversion/index.php/t12584.html) I am not sure about file size in MB, but suspect that it is not the issue.
In order to use Lightroom's library functions, I am making smaller "thumbnail" images and loading them into the database.
Arnason
by Arnason » Sat Sep 08, 2007 9:52 am
ThomasPF wrote:I think you should make it the other way, first Lightroom than APP.
Thomas
There are 7 raw images that create the pano and the final image after stitching needs quite and adjustemnt in regard of exposure, fill and saturation. Would you suggest that I copy adjustments (in Lightroom) from one image to the rest (6) convert those to tiff and stitch with Autopano?
Correct me if my thinking is wrong plesae.
ThomasPF
by ThomasPF » Sat Sep 08, 2007 4:17 pm
My workflow normally looks that way.
I open the RAW in a RAW Converter normally LR, lookf for the most critical image and do there my settings, these settings I sync to all other pictures and than I export Tiff which will be stitched. In APP you can do also some Exposure correction and stuff but I always do the final work on the Panorama with PS, cloning, probably some more shadow highlight correction and sharpening
One reason I do this, is that APP does not recognize the RAW files from my DSLR and I would prefer anyway doing the main settings before stitching the panorama like adjusting color WB and all the stuff.
Thomas
