Nikon 10.5mm / Samyang 8mm lens and D7100 or D300
All things panoramic.
Adam
Re: Nikon 10.5mm / Samyang 8mm lens and D7100 or D300
by Adam » Sat Jun 14, 2014 11:36 pm
I think I wasn't careful with "vanishing point" and leveling in software.
Here is another one
Adam
by Adam » Sun Jun 15, 2014 2:46 pm
What do you think now? I know exposure is bad, but how is stitch and NPP?
I'm trying to follow your instructions -15 and +65 degrees and 90 up, but.....
Thank you!
by mediavets » Sun Jun 15, 2014 2:52 pm
Adam wrote:Hello,
Thank you!
You need not incorporate both +65 and +90 in the stitch - either should cover the zenith - it's a belt-n-braces approach to shoot both.
The +65 is more likely to enable APP/APG to detect a link between it and the main row of 6, sometimes a +90 will just be blue sky or white ceiling and then APP/APG won't find any feature to match with the main row of 6.
So in such circumstance the +65 may work best, especially if you give some consideration to the direction in which you shoot it to ensure good features fro matching between the +65 and the main row of 6.
It doesn't take long to shoot the few extra 'zenith' and zenith shots.
Adam
by Adam » Sun Jun 15, 2014 5:44 pm
Are you recommending one +65 shots or 6 around?
Just got back from the gym.
Thanks.
by mediavets » Sun Jun 15, 2014 6:05 pm
Adam wrote:Hi,
Thanks.
I would take 3 - every other click stop if head set for 6 - but probably use just one of them.
Adam
by Adam » Sat Jun 21, 2014 8:22 pm
mediavets wrote:
Adam wrote:Thanks!
BTW I do have Nadir adapter. I forgot how to use it also.
This may help?:
https://www.youtube.com/watch?v=fr-z0Rz__5I
Is it even worth using NN Nadir adapter?
by mediavets » Sat Jun 21, 2014 8:35 pm
Adam wrote:
mediavets wrote:
Adam wrote:Thanks!
This may help?:
Yes, I think so - especially for longer exposures indoors or if bracketing - although I have yet to buy one I plan to.
Adam
by Adam » Sat Jun 21, 2014 9:16 pm
Which NN do you have?
by mediavets » Sat Jun 21, 2014 9:33 pm
Adam wrote:Which NN do you have?
I have a 5L, an NN4 and a U-R10.
Previous
