Nikon 10.5mm / Samyang 8mm lens and D7100 or D300
All things panoramic.
Adam
by Adam » Wed Jun 11, 2014 12:18 am
It would save me a lot of time, if someone could share NNP settings for above lenses and camera bodies on NN5L.
I'd really appreciate it. Thanks!
interested in panorama photography
Re: Nikon 10.5mm / Samyang 8mm lens and D7100 or D300
by mediavets » Wed Jun 11, 2014 5:35 am
Adam wrote:Hi,
This may help get you started:
http://wiki.panotools.org/Entrance_Pupil_Database
Adam
by Adam » Wed Jun 11, 2014 8:30 pm
Thank you very much.
What is the easiest method I should follow to find NNP?
by mediavets » Wed Jun 11, 2014 8:42 pm
Adam wrote:Thank you very much.
May help?:
http://www.johnhpanos.com/epcalib.htm
http://www.easypano.com/forum/display_t ... picID=4162
Adam
by Adam » Thu Jun 12, 2014 4:28 pm
I haven't shot panorama using NN5L in a few years and never with Nikon 10.5. How many shots around on DX camera and what angles do I shoot to get 360 pano.
Thank you!
by mediavets » Thu Jun 12, 2014 5:13 pm
Adam wrote:Hi,
Thank you!
Nikon 10.5 on Nikon DX (cropped) sensor body?
I use one of two shooting patterns:
1. Outdoors and in larger interiors: 6-around at about -10/-15 degrees (so that just the outer edge of the rotator is in the bottom of the frame), plus one or more 'zenith' shots at approx. +65 as this is more likely to provid a good link(s) to the main row that a +90 zenith. It's up to you how you deal with the nadir 'hole', do you have a Nadir adapter for your NN5L?
2. In smaller more confined interiors - 6-around as above plus a second row of 6-around at about +50. I know it sounds odd but it seems to work for me for such scenes.
Adam
by Adam » Thu Jun 12, 2014 5:28 pm
Thanks!
BTW I do have Nadir adapter. I forgot how to use it also.
by mediavets » Thu Jun 12, 2014 5:45 pm
Adam wrote:Thanks!
This may help?:
https://www.youtube.com/watch?v=fr-z0Rz__5I
Adam
by Adam » Thu Jun 12, 2014 10:25 pm
Is there a way in autopano pro to limit number of control points? How?
Thanks!
by mediavets » Thu Jun 12, 2014 10:43 pm
Adam wrote:Hi,
Thanks!
Why would you want to?
Adam
by Adam » Thu Jun 12, 2014 11:14 pm
it generates over 70 control points. hard to manage so many
Adam
by Adam » Thu Jun 12, 2014 11:35 pm
This nuts!
I can do better handheld than this pano on NN5. What's wrong? Please!
Thanks!
by mediavets » Fri Jun 13, 2014 7:41 am
Adam wrote:it generates over 70 control points. hard to manage so many
70 control points is hardly any for a whole panorama.
In what way do you wish/need to 'manage' CPs anyway?
A well shot pano should seldom require much if any CP editing.
Here's a pano shot with a Nikon 10.5mm FE on a Nikon DX body.
A main row of 6-around plus 'zenith' and APG found over 1,000 CPs.
by mediavets » Fri Jun 13, 2014 7:44 am
Adam wrote:Hi,
This nuts!
Thanks!
What do you think is wrong with this - other than the obvious issue with the overhead wires, and lack of zenith area.
Adam
by Adam » Fri Jun 13, 2014 12:38 pm
I meant 70 points for each image.
I've no idea why flag post and house are not stitching correctly. I spend whole gay shooting yesterday.
Thanks!
by mediavets » Fri Jun 13, 2014 12:55 pm
Adam wrote:I meant 70 points for each image.
Thanks!
70 points for each image is not a lot with the CP detection system used by APP/APG.
It would be a lot if you were placing each CP manually in, say, PTGui; but APP/APG doesn't 'work' like that.
If you wished to share a reduced size version of the image set in JPEG format - dropbox is a good way to share files - I would be happy to take a look and see what I might be going on.
Meanwhile perhaps you would like to show us a screenshot from the CP editor - like that I posted - it may give us a clue.
The flag is relatively close to the camera - the stitch issue here may indicate that your camera/lens is not set at the NPP? How confident are you that it is?
Adam
by Adam » Fri Jun 13, 2014 1:18 pm
I'll send images to Dropbox later today.
Thanks!
Adam
by Adam » Fri Jun 13, 2014 4:03 pm
I uploaded 6 images to Dropbox https://www.dropbox.com/home/Public
Thanks for all your help.
by mediavets » Fri Jun 13, 2014 5:02 pm
Adam wrote:Hi,
I cannot access that.
Adam
by Adam » Fri Jun 13, 2014 5:10 pm
what do you want me to do? I don't know much about dropbox.
by mediavets » Fri Jun 13, 2014 5:12 pm
Adam wrote:what do you want me to do? I don't know much about dropbox.
I think you may have to send an invitation via email for me to access?
I'll send you a PM via the forum with my email address.
by mediavets » Fri Jun 13, 2014 11:19 pm
I've no idea why flag post and house are not stitching correctly. I spend whole day shooting yesterday.
Thanks!
OK - I received 7 images two of which seem to be the same.
1. The flagpole doesn't stitch properly because it is moving in the wind - see screenshot 1. This can be fixed using the mask tool.
2. Regarding the house - there's something odd about the two images that overlap over the house, it's as if the tripod moved or something, they just don't align well at all - see screenshots 2 and 3.
3. You appear to have used auto white balance and auto focus this will not help the CP detection system.
4. This is a 'tricky' scene for auto CP detection - a combination of large areas of relatively featureless road surface and a lot of foliage that's moving in the wind, I guess the clouds are moving too.
5. More consideration of where the seams/overlaps will occur might have made stitching easier.
Adam
by Adam » Fri Jun 13, 2014 11:34 pm
Thank you so much for your help.
So, it's not Npp errors?
I'll try again soon and let you know. What kind of balance I should use, if not AWB. I'll use manual focus next time.
Adam
by Adam » Sat Jun 14, 2014 11:04 pm
Here is another shot at pano with 10.5. I know exposure is bad, etc., but stitching looks good to me. Even wires are okay.
What you think? I think NPP is good now.
Thanks!
by mediavets » Sat Jun 14, 2014 11:10 pm
Adam wrote:Hi,
Thanks!
Looks good at this size.
Wires are always challenging/tricky.
I wonder why the roof of the house near centre is not level.
Was your pano head levelled?
Any NPP parallax issues are more likely to be exposed shooting small interiors.
