Best Web site for displaying 360 panoramas
All things panoramic.
marzipano
Liked in: 14 posts
by marzipano » Sun Apr 13, 2014 3:02 pm
I have a number of 360 panoramas I would be keen to put onto a public website that would be available for my friends and colleagues (and anyone else) to view just using a browser (that is without the need to download any special software or the images themselves)
What sites can anyone recommend that allow the display of panoramas with the criteria:
1. Cylindrical format (that is 360 * less than 180)
2. Uploaded as jpg files
3. Auto rotation
4. Display at original resolution
5. Free to use or just a small fee
I think the need to have standard utility software installed locally like Flash Player or Java would be OK
The nearest I have found so far is Dermandar but the resolution seems to be severely reduced and it is set up for equirectangular images I think (360*180)
Any suggestions ?
Re: Best Web site for displaying 360 panoramas
by klausesser » Sun Apr 13, 2014 4:19 pm
marzipano wrote:Any suggestions ?
Yes - get yourself a webspace. Something like Server4You - about 9.-€ a month for 400GB webspace including an ip-adress.
http://www.server4you.net/vserver/
PS: i use it also for three sites. http://www.360impressions.de/AuswAlle.html
PS2: also streaming video and music: http://360impressions.de/ZuerichBar.html
marzipano
Liked in: 14 posts
by marzipano » Sun Apr 13, 2014 7:38 pm
I had a premonition you were going to say that klaus ;)
best,
Martin
by klausesser » Sun Apr 13, 2014 9:37 pm
best,
Martin
=D it´s quite logic, isn´t it . . :cool:
marzipano
Liked in: 14 posts
by marzipano » Sun Apr 27, 2014 7:27 pm
I have access to web space already via my ISP contract
The problem I have is that I have cylindrical 360 panoramas which are much narrower than the 360x180 format that most products cater for
I have tried many of them locally and tested them through Firefox and the only one that came close to a reasonable display was pano2vr. This displayed correctly if the "No 3D distortion" box is checked whereas the other ones I looked at do not have this option and display incorrectly (e.g. Google+photospheres, krpano, Epublisher, dermandar) like the incorrect example below. This is very prevalent if the camera was tilted during the shooting of the panorama as in this example
I put this up here just to see if anyone else knows any web display options that both display correctly and provide full 360 degree auto rotation
best
Martin
This is what it displays like if the "no 3D distortion" box is not checked - but it auto rotates properly
This is what I think it ought to look like and has the "no 3D distortion" box checked but only rotates backwards and forwards (not revolutions)
This is the control page showing the box in question
by mediavets » Sun Apr 27, 2014 7:46 pm
marzipano wrote:I have access to web space already via my ISP contract
What pano projection type are you using when rendering?
What stitching software are you using?
Can we download an example of the sort of panos you are having trouble with?
If you use a Spherical projection type when rendering with APG I can't see why you should have problems displaying with PT/PTP/krpano, so long as you enter the correct HFOV VFOV and vertical offset parameters, which are to be found in the Kolor EXIF tag,
marzipano
Liked in: 14 posts
by marzipano » Sun Apr 27, 2014 9:18 pm
1. I have tried cylindrical and spherical rendering
2. I use APG latest version
cylindrical:
https://www.dropbox.com/s/t48d4vh5qu9v5sn/Richmond%20hill%20.jpg
Spherical
https://www.dropbox.com/s/r35h2y2nymc4eil/Richmond%20Hill%20spherical.jpg
I can get these to display locally on my hard drive perfectly well using the download exe "wpanorama"
I cannot find anything as yet that will display them properly on the web with the criteria being:
full screen
full res (preferably)
full 360 auto rotation
straight horizon
best
Martin
by mediavets » Sun Apr 27, 2014 10:03 pm
These are two fullscreen screenshot from a virtual 'tour' (one pano) created with Panotout Pro V 2.1 using the spherical projection example you offered for download; one at full resolution. Horizon looks good to me, and it will autorotate a full 360.
What do you think?
marzipano
Liked in: 14 posts
by marzipano » Mon Apr 28, 2014 8:15 am
mediavets wrote:These are two fullscreen screenshot from a virtual 'tour' (one pano) created with Panotout Pro V 2.1 using the spherical projection example you offered for download; one at full resolution. Horizon looks good to me, and it will autorotate a full 360.
What do you think?
Thanks v much for that info -
That sounds just right !
I haven't tested that product yet so I will give it a go right now
(I hadn't realised that was what Panotour was for !!!)
by mediavets » Mon Apr 28, 2014 8:53 am
What do you think?
Make sure you check that PTP reads the Kolor EXIF data for Input HFOV, VFOV and vertical offset; enter manually if necessary.
Use panos rendered with a Spherical projection; PTP doesn't support Cylindical projection.
marzipano
Liked in: 14 posts
by marzipano » Tue Apr 29, 2014 5:54 pm
Thanks for those tips (the FOV comments are making a big difference)
One thing - some of my panos generate the error below and I can't seem to find where its coming from
They only seem to come from Panotour (2.1) , Panotour Pro is OK
Anyone seen it before ?
best
Martin
error message on some panos in Panotour 2.1
by mediavets » Tue Apr 29, 2014 6:46 pm
Yes, it has been seen and reported before - as I recall it normally means just what it says.
Do you have a hotspot that is not associated with a hotspot style?
marzipano
Liked in: 14 posts
by marzipano » Tue Apr 29, 2014 7:19 pm
I am not (intentionally !) using hotspots at all
I'm just converting panoramas straight out of APG/Photoshop/paint
I'll take another look around based on that lead
thanks,
Martin
by mediavets » Tue Apr 29, 2014 9:45 pm
marzipano wrote:I am not (intentionally !) using hotspots at all
thanks,
Martin
D you get this error message every time with Panotour standard edition?
Which version of Panotour and Panotour Pro are you using and on which OS?
marzipano
Liked in: 14 posts
by marzipano » Tue Apr 29, 2014 11:22 pm
thanks,
Martin
I downloaded the new version of Panotour (2.1 Final dated today) and the problem seems to have gone away now so maybe it was just a 2.1RC issue
Anyway - resolved now
Martin
marzipano
Liked in: 14 posts
by marzipano » Wed Apr 30, 2014 9:41 am
thanks,
Martin
Martin
FYI - I spotted the pattern as to why a "random" selection of panoramas wouldn't build in Panotour Standard 2.1RC1
It was all the ones that had been Geo-coded with Geosetter to put in the global co-ordinates
Now OK in 2,1 Final anyway !
Martin
