putting a gigapano online
All things panoramic.
inMotion
by inMotion » Fri Mar 08, 2013 6:06 am
Hey All! I have a pretty sweet ~15 gigapixel pano that i'd like to share online - ideally on a website built for the image to help promote it- maybe similar to the famous Paris 26 gigapixel. Does anyone have any knowledge or advice on how to go about doing this? From what I understand it can consume a lot of bandwidth as well. Any advice is appreciated! Thanks!!
http://vimeo.com/11328214 - My Silk Road Timelapse: Two Months Across Tibet, Xinjiang, Yunnan, and China
by mediavets » Fri Mar 08, 2013 10:39 am
If you are concerned - rightly I think - about bandwidth, if you host on your own server/Web space, then I suppose you might consider putting it online at gigapan.com :
http://gigapan.com/cms/create-upload
by klausesser » Fri Mar 08, 2013 10:44 am
inMotion wrote:Hey All! I have a pretty sweet ~15 gigapixel pano that i'd like to share online - ideally on a website built for the image to help promote it- maybe similar to the famous Paris 26 gigapixel. Does anyone have any knowledge or advice on how to go about doing this? From what I understand it can consume a lot of bandwidth as well. Any advice is appreciated! Thanks!!
Hi!
I don´t understand the question! Don´t you have any webspace? If not: get one and put the folder containing the panorama on it. Inside the folder duplicate the main.html,
rename it to "index.html" and use the folder´s name in the URL.
That´s all.
Like this: www.360impressions.de/WuppertalPad
(Desktop and iPad)
And: of course it "can consume a lot of bandwith" showing Gigapixels . . . what do you think ;):cool:
a a gruntpuddock
by a a gruntpuddock » Fri Mar 08, 2013 12:23 pm
inMotion
by inMotion » Sat Mar 09, 2013 7:56 pm
Hi!
That´s all.
(Desktop and iPad)
thanks, looks nice! how did you generate the HTML and images for that from autopano?
by klausesser » Sun Mar 10, 2013 2:03 am
inMotion wrote:thanks, looks nice! how did you generate the HTML and images for that from autopano?
I used PanoTourPro.
